Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Difference between 1.2v and 1.5v AA's
Reply
Old 11-12-2006, 06:46 PM
asinla
asinla's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Difference between 1.2v and 1.5v AA's
Just a quick question I'm sure someone here will have the answer to.
I recently purchased some AA and AAA rechargeables to use in my RTF tx's. I also purchased a Picco Z heli which charges off the batts in the tx. I noticed that the NiMH rechargeable batts were only available in 1.2v. I know Alkaline batts are 1.5v.
Is there any loss of performance by using the 1.2v batts and how come they don't make 1.5v NiMH rechargeables??
Thanks.
asinla
asinla is offline
Old 11-12-2006, 07:49 PM
Flying Geezer
My Feedback: (14)
Flying Geezer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Difference between 1.2v and 1.5v AA's
Nicad and NiMh rechargeablecells have a nominal voltage of 1.2 V. Fully charged they measure about 1.4 V. Alkaline and other dry cells have a voltage of 1.5 when fresh.
You can use them interchangably in your TX. Either will provide plenty of power.
The difference in voltage of a fresh dry cell and a fully charged nickel based cell is a characteristic of the chemistries. It wasn't planned that way, it's just the way it is.
Hope this helps,
Flying Geezer is offline
Old 11-13-2006, 04:39 PM
Red Scholefield
Banned
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Flying Geezer
Nicad and NiMh rechargeablecells have a nominal voltage of 1.2 V. Fully charged they measure about 1.4 V. Alkaline and other dry cells have a voltage of 1.5 when fresh. But under any significant load they will drop to 1.2 volts or so.
You can use them interchangably in your TX. Either will provide plenty of power. And the alkaline cells (dry cells)have a much more sloping discharge than either the Ni-Cd or Ni-Mh so you can check how much you have left by simply measuring the voltage (or keeping an eye on your transmitter meter if you have one)
Hope this helps,
Red Scholefield is offline
Old 11-13-2006, 07:37 PM
asinla
asinla's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks so much for that concise and precise explanation. It does make a lot of sense actually now that I look at it like that.
Thanks again
asinla
asinla is offline
Contact Us Archive Advertising Cookie Policy
