LiPo charging and balancing questions
GA
Ok, I've got a 2 cell and a 3 cell pcak (800 & 1250ma respectivly). The 2 cell pack has always been charged using a balancing charger at 650ma. The 3 cell pack has been charged via the discharge wires at 1A. Both seem to be charging well in between 1 -1 1/2 hours. The 2 cell has a total, no load voltage (straight off the charger) of 8.32v with one cell reading 4.15v and the other reading 4.17v.
The 3 cell has a total, no load voltage of 12.48v with each cell reading 4.16v
Both batteries are physically perfect, cooled before charging and kept cool during the charge process and seem to give very good performance and run times.
My questions;
I've read that the nominal full charge voltage shold be 4.2v. Are my slightly lower readings a problem or concern?
Is the .02v difference in the 2 cell individual cell voltages something to be concerned about. And what's the point of using a balance charger if it does not charge the cells to the same voltage?
Does it really matter if I charge with the discharge wires as long as I stay at or below the 1C charge rate?
My questions;
GA
RE: LiPo charging and balancing questions
4.2 per cell is considered 100% state of charge however most chargers do not charge that high. They may reach that while charging however if you check 15min. after charging most likely range would be 4.14 -4.17 per cell.
4.14 = 94% / 4.17 = 97%
An imbalance of 0.02 volts is fine. Most do not become concerned unleess it is 0.04 or more.
