If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 15 of 15
  1. #1
    Join Date
    Jan 2007
    Auckland, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    2200mAh battery how do i charge it?
    Hi I have just got a Accu-Cycle Elite charger. I have also bout a battery Link to ebay bought battery if that link does not work then this is the ebay number 160067021941. The battery has a small white connector which I assume is for charging it. I have nothing like that with the charger, what sort of connection is it so I can find it so I can buy one for the charger or is it something else. Please help an idiot (i dont have a heil yet, still waiting so be patient with me). What do I do?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #2
    Bob Laine's Avatar
    Join Date
    Jan 2002
    Loganville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 2200mAh battery how do i charge it?
    I would suggest you go to the item you bought and ask the seller the question. What are the two plugs for, and which one is used for charging. Myself.......I'd take a volt meter and see which one has the voltage, and I'd change the plugs to whatever radio I'm using. I suspect that one of the plugs will go to the receiver and the other plug is used for charging. You can probably eliminate one of the plugs if you change the other to accept the plug on the switch you intend to use if you use a switch with built in charge receptacle. Still........the best thing would be to ask the supplier. Bob Laine
    \"Georgia on my mind\"
    AMA 8143 \"Leader Member\"
  3. #3
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Elite charges thru the discharge (using) plug. The 2 wire plug.
    The white connector is for cell balancing.
    and airplanes were in
  4. #4
    Join Date
    Jan 2005
    Lawrenceville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The white connector is for using a balance charger or device to balance the cells.
    The charger you have will charge it thru the deans (red) connector.
    Lanny http://www.poshpottery.com/airplane.html
    P-51 Mustang,3DFoamy,ME-109,SPAD Debonair, UltraFly Furious 3D,Formosa
  5. #5
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Excellent thanks for that. So I thought I would plug it in and just see what it does (without any battery). I bought the charger from Canada so I used my travel plug popped it in and BANG! Now I will have to get a transformer aswell!
  6. #6
    Join Date
    Apr 2002
    Locust Grove, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You can charge two ways.
    All three cells as a 3 cell LiPo pack or any two adjacent two wires on the white connector as a single cell.
    Be careful of the polarity.
    Aircraft Proving Grounds
    http://www.rcaircraft.net/
    Information on the building and flying of Radio Control Aircraft.
    Site for hobbyist in the R.C. Aircraft modeling world.
  7. #7
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    so going with the big reg one it the better way for someone who is unsure.
  8. #8
    Join Date
    Jan 2005
    Lawrenceville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes. That is what I use. To help make your batteries last longer you will need to get a balancer. I bought the Ultra-Balancer from Common Sense RC ( http://www.commonsenserc.com/product...roducts_id=184 ) and I like it. Works with all my batteries.
    ORIGINAL: zulugogogo
  9. #9
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok, what is a balancer? why isnt it built in?
  10. #10
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have just seen a charger/balancer for $24.00 and i paid $100 for mine AND i need a balancer! can someone explaine?
  11. #11
    Join Date
    Jan 2005
    Lawrenceville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You got a very good charger for the price. You dont have to use a balancer. I have batteries I have had for months (charged 60 or 70 times) and they still work fine and never been balanced. I just now started flying helis so my battery demand has increased (4 - 2cell, 12 - 3cell lipos). That is why I got the balancer.
  12. #12
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can you explain what the balancer does in simple terms.
  13. #13
    Join Date
    Jan 2005
    Lawrenceville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A Lipo battery has a number of cells. Each cell has a voltage of 3.2 volts or higher. From charging and discharging the voltage in the cells can get unbalanced. A balancer will identyfy the voltage of each cell and bleed off the higher voltage until they are equal.
    Basic Lipo info
    http://www.commonsenserc.com/product...guidelines.pdf
    Balancer info
    http://www.commonsenserc.com/product...ions_final.pdf
  14. #14
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks again for your help
  15. #15
    Join Date
    Apr 2002
    Locust Grove, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A balancer will charge each individual cell to ensure that each cell is fully charged.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
