Charging Fromeco Relion???
My Feedback: (84)
WI
RE: Charging Fromeco Relion???
If you got the pack new you should have the Fromeco charge info, or go to the website. O.5 amp to 0.8 amp and a max voltage of 8.40 v. (Check this info for the exact type of battery) Listed are the recommended max current and the max voltage. Any charger that is designed for Lipoly/ION will work if set to Fromeco’s curent and max voltage. You should contact Astro Flight and Fromeco to be sure. I charge my Relion’s with Triton II, Accu Cycle Elite, Hobbico Quick Field Charger MK II and NMP for field top off only. I check the IONs with the Fromeco 8 Ball checker (COOL checker), have not had a problem.
The proper charge current as specified by the manufacturer of the cells Fromeco uses is 0.5C to 1.0C. The original Fromeco charger had a default charge rate of 2A charge rate which is fine.
