Question about Extra Cell in RX pack
My Feedback: (24)
I'm a real noob when it comes to these RX packs. I bought a used radio at a swap meet a while back and I found that the guy has put an extra cell in the RX pack. He told me it pushed the servos a little harder? Is this true? I've got the setup in a plane of mine and the whole thing is pretty snappy. I haven't had any problems with it.
My question being, can I do this to my one of my hitec setups? It looks like a standard 600mAH 4 cell pack. Would adding another cell give it some more power? It's a simple Focus 4 with HS300 servos, very basic, but It would be nice to get a little bit quicker movement from them.
The only way you can get more power is by putting in a bigger engine
For practical purposes, you will not notice, any improvement with an extra cell in your application.
yes
Yes, if you use a 5-cell pack instead of a 4-cell, you now have more power to output to your servos. You should read the manufacturer's recommendation to determine the max voltage Rx pack you can safely use.
Banned
My Feedback: (9)
Pros and cons of 4 vs 5 cell packs for rx
4 vs 5 cells for receiver packs
· 4 cells cost less
· 4 cells are more reliable than 5 (more parts/connections = less reliability)
· 4 cells give you longer flying time than 5 cells of equal capacity
· 4 cells are lighter
· 4 cells put less stress on radio and servo components (unless regulator is employed)
· 5 cells give you faster servo response
· 5 cells allow for voltage regulation to give you constant servo response.
· 5 cells give you a margin of safety if one cell shorts (but this is a rare occurrence in flight – if you don’t do an ESV check before you start flying, then you deserve what you get.)
Usually same charger that comes with your radio system will accommodate both 4 and 5 cells, for 5 cells the charge may take slightly longer. A standard Futaba Charger will charge 5 cells at about 40 mA, whereas it charges a 4 cell pack at 55 mA. For 5 cells charge 20% longer.
All present day radio systems seem to accommodate 5 cell receiver packs without problems.
· 4 cells cost less
