I need a good Balancer
WI
What would you all recommend for a good balancer? I just got a new Super Brain 989 so I am in the market to get a good balancer. Thanks
RE: I need a good Balancer
Our ultra balancer can handle up to 6s and works either with a charger or as a stand alone balancer. It is available in the charger section of our website.
Ryan Lefevre
www.CommonSenseRC.com
The Go To Guys For Electric Power
Ryan Lefevre
what brand of battery packs will you be using?
btw the csrc is a good balancer, and pretty much the same thing as the blinky
My Feedback: (282)
Look at the e-Station PB-6.
http://www.rcaccessory.com/index.asp...ROD&ProdID=191
This is the balancer that you will not outgrow.
Does up to 6S and expandable to 12S via link cable linking 2 together. This also can be used to balance 2 seperate packs being charged serial too.
The e-Station PB-6 does Li-Poly, Li-Ion, and Li-Fe (A123 Systems).
The e-Station PB-6 also has the highest bleed rate at 500 ma. This is necessary when you use larger packs. Most balancers have very low bleed rates from 80 to 120 ma.
We support like 98% of the available lipoly packs on the market via a connection board. Each connection board will do from 2S to 6S and 1 connection board of your choice is included.
Here is a link to the configuration guide of the batteries that we support:
http://www.rcaccessory.com/pdf/Batte...on%20Guide.pdf
You will not find a more complete, easier to use balancer on the market.
RC Accessory, Inc.
Auth US Bantam Importer
RC Accessory, Inc.
WI
ON, CANADA
I have two Super Brain 989's and use the Hyperion LBA10A 1-6 cell balancer. They work very well and can balance A123 cells too. I have Emoli cells.
[link=http://www.cheapbatterypacks.com/?sid=716896&pgid=chrg&scat=bal]Hyperion LBA10A[/link]
ORIGINAL: huggins
Not to be a smart a.., but here is a good balancer....
Mike
Mike
lol, that is indeed where can I pick me up one?!
