Fromeco Ion Cube
My Feedback: (9)
KS
Fromeco Ion Cube
I have a Fromeco Ion Cube (I purchased one with the brain and filled 3 of the 5 slots if you are familiar with the Cube) that I will be using to charge 3 2600 Fromeco Lithium Ion packs that I recently purchased. I have a marine battery installed in a Haulmark trailer that is wired to 2 110 volt outlets. My question is.....do I really need a power supply if I plan to normally do my charging in the trailer when I am at home? Or would it be better for some reason if I get a power supply to charge at home?
I am planning on charging at the field using a battery jump box for convenience if I need to.
Also, one other thing is that I normally have my trailer plugged into a wall outlet so my marine battery stays fully charged.
Thanks in advance,
Keith
Thanks in advance,
Keith
