Hypersonic charger
GA
RE: Hypersonic charger
A123 Web Site
http://www.a123racing.com/html/soniccharge.html
Now I am sure that it would charge a 4S pack two cells at a time if you made an adapter however it is really one of those areas where if you have to ask then the answer is no.
Charles
product specs
Power Supply: 10-15V DC
Charge Cells: 1-3 (Hypersonic™ Packs Only)
Cell Balancing: Yes
Pole Reversal Protection: Yes
Charging Power: Max. 108W
Charging Current: Max. 10A
Charging Voltage: 3.5-10.5V
Status Indicators: LED
Fuse: 15A Auto Style Spade Fuse, Input & output
Dimensions (W x H x D): 126 x 46 x 82 mm
Cell Balancing: Yes
Charles
NC
Hey ive got a dumb question. where do yall plug these chargers in? do you hook it up to a car battery or does it come with an adapter with a wall plug. im about to get one and im not seeing a standard 115V plug.[sm=confused_smile.gif]
GA
Very few chargers come with AC power capabilities built in ,most especially higher output ones.
You will need a AC to DC 12-15 volts power supply and it should be at least 12 amps. and more is always better.
A automotive battery will work however be advised that based on my rather extensive experience these batteries take approx. 2/3 (0.66) Ah per cell per charge, so a 3S pack takes 2Ah from a 12V deep cycle per charge.
Due to the way many 12v batteries are rated a 7Ah sealed type would do well to last two charges.
Charles
Charles
