imaxb8 power source?
My Feedback: (29)
AZ
i just got the imaxb8 charger, i tried to use it with my power converter from my hobbico accu cycle, says it puts out 14.5v and 2.5 amps, well the imax gives me a low volt input warning and wont work, the manual says 11-18 volts but nothing about amps, when i hook up to my 12v battery in my field box it works like a charm, is there something wrong somewhere? is it the 2.5 amps? what kind of inverter would i need to run this thing at home? i see ones from places like jc whitney that are ajustable, any info would be apprectiated, thanks
My Feedback: (29)
AZ
RE: imaxb8 power source?
thank you, i will check some out, aprreciate it, now i just need to find balancing adapters for my flight power battery pack, god-forbid anybody makes anything univeral these days, haha
My Feedback: (29)
AZ
forgot to ask, could there be too much amps?? i looked at one that was 18 amps, another that was 36 amps, would they be more effecient or just wasted amps? possibly damaging? the one from astroflight is 12.5 amps i believe for $65, that may be perfect right? so i can take full advantage of the charger but not be overkill??
No such thing as too much amps but anything over 10A is a wasted amps for this charger. 12.5A is not over killed but, to my wallet, $65 is.
My Feedback: (29)
AZ
thanks alot for the info, i splurged and got this one, 15amps, maybe i can find more uses for it, plus i saw somewhere else that triton charger reccommended a 10amp but for 8cells get the 15amp, so i figure this one will do everything i need and then some, kind grow with it, haha...have to justify the $ somehow in my mind
http://www.rivergatedist.com/bulldog_15_amp.htm
My Feedback: (29)
AZ
i havent had any issues with mine yet, works like a charm, starting to get warm here too as far as ambient temperature, so when it gets hot at the field and i am charging something, that should be a good test
