Battery Maintenance Question: How to?
CT
I use Accu-cycle plus peak chargers, and 1400/1700mah 6 cell nicads for my helis. I have been giving the batteries a full charge at a rate of 1000ma and then discharging at 250ma(I have the option to discharge at 750ma). Then I note the discharge time and check the voltage after the recharge. Is my discharge rate sufficient? Does it make a differance? Is the charge rate ok for the size packs I have?
Does someone have a good battery maintenance methodology and suggestion for good equipment? How often should I cycle(Test) the batteries?
Banned
My Feedback: (9)
Your charge rates are OK for the capacity of the packs you are charging. Discharge rates: the lower the rate the deeper the discharge. Cells are rated at C/5 discharge, so if you want to get as close to factory rating discharge at this rate.
Check the Battery Clinic for additional information on the care of your Ni-Cds.
