SuperNova 3000 charger
Bought this charger but the LHS owner goes after the manual which was missing in the box. There's a small connection on the left side of the charger, what is it for?
Also, if somebody knows where to download a manual it would be really appreciated
Thanks in advance,
G.J.
Thanks in advance,
G.J.
Hello Viper 1
I've got a supernova 3000 but have lost my instruction. I'm guessing that small connector is for charging RX packs. Put my multimeter across the pins and got 5 volts, but have been unable to draw any current from it yet. I'll do some more investigating. As for the manual I can't help but I found a product review that might help. Its from a different market where its not called a supernova, but has relavant info.
http://www.rcbatteryclinic.com/infinity2.htm
or try google search for instruction for "Robbe Power Peak Infinity 2" instead of supernova 3000. Good luck.
Thank you so much, Hyrax
I had a feeling this charger was known under another name just like the 250S ,
Got a pleasant surprise when searching for Infinity;
The plug is actually to connect the charger to the PC to receive the data sent by the charger. You can view the charge-/discharge curves.
You can download (Free) software with a printing-function in it, a simple connection diagram is also on-line available.
Thanks again,
Gert.
Thanks again,
Gert.
That would be awesome to plot the charge/discharge curves and see how your batteries are performing. Could you please post a link to the software and online information you spoke off.
Cheers
Cheers
NC
I have my Orbit Microlader hooked up to my laptop to watch the charge/discharge curves. It's definitely interesting to watch. Probably about 10% useful info, and 90% just sort of neat to see.
You have to download a program called ' Opeak '
from here:
http://www.opeak.de/german/download/index.htm
You can use a 9 or 25 pin sub-D connecter
for the connection:
http://www.opeak.de/german/software/hard.htm
Unfortunately the English page is not up yet, If you need help with the manual I think I can translate it for you, just drop me an email.
from here:
for the connection:
Thanks Viper1,
I downloaded the software, went to JayCar and got a plug to fit side of charger and a 9 pin serial port plug. Made up a cable and it works sweet. Cool to watch.
Hyrax
Hyrax
