Flightpower EVO30 vs. EVO25
CO
Has anyone tried the new EVO30 packs? Specifically, I am currently using an EVO25 2170mah 3S pack in a mini titan with a Scorpion power system. I am curious if the EVO30 2000mah is worth trying. It appears it may give me a little more kick. Thoughts anyone?
CO
RE: Flightpower EVO30 vs. EVO25
Well, I am running the Scorpion 2221-8 with the Commander 45A V1 speed control. Not sure what amperage that setup is pulling. I was just curious if I would notice more "punch" with the 30C pack.
CO
Yes, makes sense now. I suppose I would need to upgrade the ESC to feel a difference. Will an ESC rated at 45A max continuous deliver a higher burst amperage, or is 45A the limit?
I'm no electrical power systems stud but I say that if your setup (pinion, motor combo) pulls more amps than your esc can handle you let the magic smoke out of the ESC. If your ESC is rated at more amps than the battery and you pull too much current the LIPO will puff up.
