Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
lipo's in paralell?
Reply
Old 12-04-2008, 08:32 PM
thestratcat
thestratcat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default lipo's in paralell?
ok, I'm a heli guy, and very electrically impaired.
with that said, I got an e-flite pitts bi-plane that requires an 11.1 4200mah lipo pack to power it... my question is, can I wire the packs I have that are 11.1 volt, 2100 mah in paralell to get the power I need? if I can, how do I do it?
thanks....
thestratcat is offline
Old 12-05-2008, 11:30 AM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: lipo's in paralell?
Yes, works very well.
Rodney is offline
Old 12-05-2008, 02:26 PM
Druss
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: thestratcat
thanks....
You can either direct wire them to one connector or you can make/buy a parallel connector like the one in the pic.
ID:	1084293   Click image for larger version
Druss is offline
Old 12-05-2008, 03:33 PM
BarracudaHockey
Community Moderators
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Batteries in series: Add the voltage, capacity remains the same.
EX: 2 10 volt, 1000mah batteries wired in series would result in a 20v (2s) 1000mah battery pack.
Batteries in parallel: Add capacity, voltage remains the same.
EX: 2 10v, 1000mah batteries in parallel would result in a 10v 2000mah battery pack.
BarracudaHockey is offline
Old 12-05-2008, 07:06 PM
thestratcat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok, great!!! thanks....
now the question that crossed my mind, they also have a hotter setup for 3d which requires a 14.4 volt 2250mah pack....
if I'm going to have two three cell packs on board, couldn't I wire them in series giving me 22.2 volts and 2200mah from what i have now and then use a stepdown regulator to lower my voltage to 14.8 volts? maybe it would be a better setup?
Old 12-05-2008, 10:24 PM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
4 cells is 14v, regulating from 6s down to 4s is bleeding off a lot of voltage as heat. Seems inefficent to me.
Old 12-06-2008, 03:00 AM
thestratcat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
'cuda..... thanks man...
thanks man.. thinking it through, if I was going to go to the added expense of dropping the voltage, I may as well buy a charger that will to 4 cells (both of mine only do 3 cells) and a battery.... I guess I'm just trying to play out options in my mind..
Reply
Display Modes
