Things went south
MB, CANADA
Things went south
Hey, i recently purchased a hangar 9 perfect peak charger. I also had a RX battery made up for me (sanyo cells 4.8V 1500maH and Nimh) This charger is capable of Nicad and Nimh batteries. I have used it to charge my 1500 mah pack before without problems. Tonight, the thing was taking forever to charge, and when i went to check on the battery pack, the room was filled with this god awful stench and smoke. I soon realized that the battery pack had ruptured and almost burnt the model. The charger must have automatically shut off. Now i wonder if this is the battery's fault, the charger, or mine. I would like to try the charger again, but dont want to risk another battery pack. Also my servos, the switch harness and reciever are covered in a oily smelly substance. It looks like it sprayed back into the model. How should i clean this off? and should i use this equipment again? I have never seen anything like this in my life. It scared the crap out of me and almost started a fire.
RE: Things went south
Ditch the peak detecting charger for charging receiver and transmitter packs. An overnight charger set to 150mA will give you a full charge and won't damge the batteries
Pete
Pete
