Battery charging ????'s.
I have a Turnigy battery charger. I've forgotten how to charge up Nimh batteries. I have 1 battery for my glow plug ignitor that had its own charger. Takes to long. It is 1.2 Volts and SC 1800 mAh. The other battery is a receiver battery and it is 6 Volts 1100 mAh. What is the charge rate on these and all of that and is there a quick way of doing this other than going through the program? I bought this charger for my Lipo's and that is no problem. Then the charger for the glow plug igniter went bad. I can charge it with this charger. I bought a battery pack for my receiver and it is also Nimh. Both batteries are. Thanks for the help.
RE: Battery charging ????'s.
Here is some very good info on batteries, well worth your time to read them, especially the first one.
http://www.hangtimes.com/redsbatteryclinic.html
http://www.camlight.com/techinfo/techtips.html
http://www.whenshtf.com/showthread.php?t=2153
http://www.srbatteries.com/nimh.htm
http://dansdata.com/gz011.htm
http://users.frii.com/dlc/battery.htm
You will get a lot of not so good info here in the forums, not intentionally but just due to ignorance or rumours. The stated sites are all very reliable.
