A123 Help???
IA
A123 Help???
I need some help with how to use these batteries.
My Questions:
1. What charger to buy?
2. How do you check before each flight and what checker to buy?
3. How many flights per charge (35% Edge 540 using 2 packs on 1 reciever controlled by a smartfly)?
Thanks for the help.
My Questions:
GA
RE: A123 Help???
Go to the 123 faq section of the hangtimes hobbies web site. It will answer all your questions.
http://www.hangtimes.com/
John
John
CO
RE: A123 Help???
ORIGINAL: Edgeomatic
So you can't check after every flight? You just rely on the math problem and hope nothing sudden happens?
My Feedback: (41)
RE: A123 Help???
My Questions:
FMA Direct Cell Pro 4S
Like he said, just fly a few flights. Then see what goes into the pack(s) when you recharge. Divide that by the number of flights. You can also just do one flight at first. When you see what you get per flight, I bet about 400 mah per 10 minute flight in your case, figure out how much capacity you need. In your case 2x2300 is good for probably about 5 flights. You'd have 50% left of your capacity. That's plenty of safety margin. If you balance charge is GREATLY reduces the risk of losing a pack in flight. First the balance charge is the best type of charge you can do, and it will detect a pack problem during charging. Especially the Cell Pro. I have 100% faith in this system.
3. How many flights per charge (35% Edge 540 using 2 packs on 1 receiver controlled by a smartfly)?
See above.
My Questions:
See above.
IA
RE: A123 Help???
So to be safe I could just charge every 4 or 5 flights then? Can you check voltage to just insure that both cells are good? My only worry is loosing a cell like the Fromco Batteries have before for me.
My Feedback: (41)
RE: A123 Help???
Yep probably more like 5 flights. If you use one charger, you'd probably do both in 20 minutes. With two, 10 minutes.
First the A123 cells are much more robust than any other technology. That's why they were developed for power tools. They can take a lot of abuse. Much more than the Lithium Iion, which is what I'm guessing the Fromeco was? Lion don't have anywhere near the charge and discharge rate the A123 do (55 amps on the 2300). So the A123 won't get damaged from charging. They can take a lot of charge/discharge cycles. They can take a lot of physical abuse too. Any battery can go bad no matter what technology it is. Because you are balance charging you will likely catch it far in advance of losing a cell in flight. These new balance chargers have great error cheking while it charges. The Fromeco Lion are not in the same ball park as the A123.
Also you can discharge check the new A123 packs which is what all of us are doing. My AccuCycle Elite does it. Down to 5.5 volts at the lowest. Or 6V if you like. It won't hurt it. Just not down to 4 volts or something excessive like that. The Triton also discharge cycles.
If you use all the above guidlines your chances are pretty low to have problems in flight. I have two 50cc hard core 3D planes setup with a single 2300 and I'm thrilled with the packs. I'll never go back to the high discharge NiMh. They worked ok but the A123 charge in 10 minutes at 4 amps. They maintain a constant 6.6 volts under any load. Impressive.
MB, CANADA
RE: A123 Help???
Hangtime sells the voltmagic. It will work like a fuel gauge and it also does much more. I use mine and enjoy the piece of mind. I also use the FMA multi 4 and I did the mod to balance charge right thru my charge jack.
http://www.voltmagic.com/
My Feedback: (80)
RE: A123 Help???
i Have three thunder power 610c chargers I use on my A123's. I think its a great charger and simple to use. Many different modes for charging and will charge at 10 amps. I have A123's in all my aircraft. I typically run a redundant setup. I have two Fromeco Iron corps extreme 2300 mah in my extreme flight extra and I can fly all day long and still am yet to put half the capacity pack in after a days flying. i think they're great batteries
RE: A123 Help???
My Questions:
My Questions:
For a charger, I purchased a CellPro Multi4. It's a good charger that is very versatile and easy to use. You can find out more about the charger on its web at www.fmadirect.com.
I have 3 giant scale planes with the same battery set-up, one 2300 mah A123 for the ignition, and two 2300 mah A123 for the flight pack. I use two packs for the RX for safety back-up. I usually get 5-6 flights out of each charge before I re-charge all packs and, at that time, I still have only used about 20-30% of the packs capacity. On average, after 5-6 flights, my CellPro Multi4 restores about 400-450 mah to each pack. The Multi4 provides good diagnosis and information about your packs after each charge.
One of the negatives about A123's, is that you can't put a volt meter on it to check the pack because of one of the benefits of the technology is its constatnt voltage. The way I check my packs is to charge them just before I go out to fly and after the charge cycle my Multi4 gives a good read out on battery fuel level. If I still have concerns, then, after 1-2 filghts, I recharge and check the readings again. On average, I use about 80-90 mah per flight and with 2300 mah in the pack you have plenty of spare capacity.
Capt Lou
GA
RE: A123 Help???
Can you supply a pic of the pack in question? If it is from hangtime hobbies the A123's could have been ordered with a single lead. If this is the case charging and balancing would be accomplished thru a common lead. The charger would have to be able to handle this. The FMA Multi 4 is one such charger.
Hope this helps.
John
Hope this helps.
John
My Feedback: (41)
RE: A123 Help???
Thanks for all the help. I have recently found out that I don't have balancer plugs on my batteries. How should I go about this problem?
Jake I'm attaching the picture you e-mailed me so others can see what you have. I advised Jake to have Deans micro 3-pin balance plugs installed on the packs so he can leave them plugged into his Smart Fly. That way he can charge at 4 amps without melting his balance plugs. These Deans are good up to 10 amps. Then you can make a 3-pin Deans micro adapter for your charger. That would be the trick setup (this is what I have but I have the charge jack version so I can charge from the outside of my fuse).
If you didn't want to do all that, the minimum you'd have to do is take the charge plug/leads that comes with the Cell Pro and solder the black and red leads to a Dean's Ultra male plug. Then you'd have to unplug each battery from the Smart Fly and plug them into Cell Pro to charge. But this would not be a balance charge which totally defeats the Cell Pro's main benefit: balance charging.
