Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
VOLTWATCH
Reply
Old 08-04-2010, 08:17 AM
tacx
tacx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default VOLTWATCH
Hi All,
Quick question. Will "Voltwatch" work with A123 2cell Rx packs?
Tom
tacx is offline
Old 08-04-2010, 12:06 PM
Charlie P.
Charlie P.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: VOLTWATCH
Only if they are 4.8 or 6 volts.
Charlie P. is offline
Old 08-04-2010, 12:21 PM
exeter_acres
exeter_acres's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no it will not.......
due to the discharge curve of a 123 pack, it won't tell you anything.
exeter_acres is offline
Old 08-04-2010, 12:29 PM
ALWAYSPDG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
VoltMagic On-Board System Monitor
NEW!! Now includes A123 Support!
We’re thrilled to introduce the ultimate in integrated monitoring systems for your Radio Gear and Battery Packs. VoltMagic monitors pack voltage, radio glitches, peak low voltage and intermittent system interruptions and will even track and report marginal Voltage Regulator and/or Battery Pack performance under actual flight loads!
Up till now you’d have to spend hundreds of dollars and drag along a laptop to get this kind of data on flight safety critical system performance. Ideal for high-drain, high load digital servo applications! If you’ve got an aggressive 3D or aerobatic aircraft THIS device is what you need. Easy to install (just plug it into your receiver), simple to program and it weighs less than an ounce. Reports at the end of your flight the peak low voltage sustained under load, the number (if any) of glitches or 'radio hits' and stores the info for display even after you turn your radio system off! Constant real-time reporting of actual voltage of your system!
For use with 2.4 GHz, PCM or regular FM radios systems, 4 cell and 5 cell Nicad or NiMH packs, 2 cell Lithium, including specialized programing options for A123 packs. Works seamlessly in all types of system installations; including regulated systems!
Introductory Priced, Just $39.95 In stock & Shipping Now!!
Try http://www.hangtimes.com/chargers.html
Hope this helps you, Mike
ALWAYSPDG is offline
Old 08-04-2010, 12:42 PM
exeter_acres
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool... wasn't aware...
curious how it handles the extremely flat discharge curve of the A123 chenistry....
Old 08-07-2010, 08:38 PM
Mikecam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It handles it just fine and tells you some other cool things. Wouldn't trust my EF Yak to anything else.
Mikecam is offline
Old 08-08-2010, 12:08 PM
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
also try Hyperion EOS Battery Sentry. It provides information on cell voltage and pack capacity for NiXX and LiXX
TimBle is offline
Contact Us Archive Advertising Cookie Policy
