How to wrap a home made battery pack?
Can we pack a home made battery pack the same way a futaba or another battery company does? The real hard and tight plastic film...Can it be done at home? If not, how do people pack their home made packs so that soldering on it stays safe and doesnt get damaged etc.
I'm guessing that the various battery pack manufacturers use heat-shrink wrap... I'm not sure how you would get hold of stuff that large though(mind you, I haven't actually looked for it...) The other thing that might work is black electrical tape....
Re: How to wrap a home made battery pack?
1 Attachment(s)
Originally posted by Ragz Can we pack a home made battery pack the same way a futaba or another battery company does? The real hard and tight plastic film...Can it be done at home? If not, how do people pack their home made packs so that soldering on it stays safe and doesnt get damaged etc. You are better off working with cells that come with solder tabs for making up flight packs. I recommend a strip of insulation under the wire leading over the ends of the cells. Cut up a plastic milk carton for insulation material. Then as the wires come over the end of the cell a piece of cloth medical tape serves as a strain relief. Slip on you heat shrink and blow some hot on it and you are in business. |
I use black electrical tape or clear packing tape (so I can read the capacity :D)
Now for just WHERE to get shrink wrap for your cells...
Dear Ragz:
The PIPE Here again...and over here in the USA, TNR Technical (at http://www.tnrtechnical.com/shrinkwrap.html for THEIR page for it) , Radical RC (at http://radicalrc.secure-mall.com/sho...=47&cart=59639 for their shrink wrap AND MORE "battery pack parts") and CheapBatteryPacks (at http://www.unipros.com/battpacks/mai...ssion_id=41520 ...scroll down about 75 to 80 percent of the way down to see THEIR shrink wrap tubing) have the plastic shrink wrap to use to cover up your own battery packs! The type of electric hot air gun used to shrink model aircraft plastic or fabric covering can EASILY be used to shrink these types of shrink wrap "tubes" to tightly cover your battery packs...and for a "tip" here, you'd want to leave about 8 to 10 mm "extra" length on EACH end of the tube to allow it to properly cover the batteries, so that they stay together well after shrinking. Hope these links help you out...and good luck in getting some! Yours Sincerely, The PIPE! ;) |
Re: Now for just WHERE to get shrink wrap for your cells...
Originally posted by The PIPE Dear Ragz: and for a "tip" here, you'd want to leave about 8 to 10 mm "extra" length on EACH end of the tube to allow it to properly cover the batteries, so that they stay together well after shrinking. Yours Sincerely, The PIPE! ;) |
Well, I DO use some SILICONE adhesive on my cells...
Dear Red:
The PIPE here again-forgot to mention THAT important step-distracted by a severe THUNDERSTORM threat this evening in New England, thankfully THAT has passed...! I'm using a "flowable" silicone RTV adhesive on my homemade flat configuration NiMH packs, which seems to be the "most versatile configuration" for my needs, anyway. I always allow the silicone to "de-vinegar"...that is, to allow the acetic acid fumes from the curing silicone to COMPLETELY dissipate over a 24 hour period, so that none of that acetic acid gets sort-of "trapped" inside the heat shrink! I just finished up a new NiMH pack assembled that way last weekend, before using the 72mm shrink tubing I had purchased from TNR to make it up- the Sanyo AA-sized 1650 mAH NiMH cells I'm using as the "main pack" for my first MicroStar knobby radio is a bit SMALLER than the older 1400 mAH A-sized NiCad pack that WAS in there, that was a bit TOO fat for the radio...pressing on the wiring, and placing undue stress on it...so the somewhat smaller AA sized NiMH pack looks to be a PEREFECT fit in the case now. It's accepting a 1750 mA charge from one of my FMA SuperNova, at an almost "C/5th" rate of 300 mA on a NiCad setting, so I'm "blessed" with a pack that SHOULD do rather well...just found out from FMA this Friday that I should have the "Ham side" of my new MicroStar (an FMA RFD1FM50 deck on Ch.03, and two Quantum-8 "Ace style" negative shift 50 MHz receivers) by the Labor Day weekend! But thanks for the reminder, Red, on GLUING the cells together first BEFORE heat shrink wrapping them...and that silicone adhesive IS a great way to get the cells for a new pack together, but it's ALWAYS best to give that sort of stuff the full 24 hours to "de-vinegar" itself before slipping on the heat shrink covering! Yours Sincerely, The PIPE! ;) |
do you think I could us some ultracote or monokote, wrap around & glue ends together then shrink with heat gun. What do you think???
Gil |
great info guys..thanks..
Originally posted by RCISMYLIFE do you think I could us some ultracote or monokote, wrap around & glue ends together then shrink with heat gun. What do you think??? Gil i use RC car battery shrink wrap or clearly superior shrink wrap from www.nyblimp.com , both are clear. Dylan |
