RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Batteries & Chargers (http://www.rcuniverse.com/forum/batteries-chargers-84/)
-   -   Do hobbico LiFe packs load test just like normal batteries? (http://www.rcuniverse.com/forum/batteries-chargers-84/11292469-do-hobbico-life-packs-load-test-just-like-normal-batteries.html)
FenderBean 11-09-2012 06:44 PM
If so whats the stop fly voltage under a 1 amp load on a 6.6v pack? Im not talking about A123s by the way thanks
K-Bob 11-10-2012 02:47 PM
RE: Do hobbico LiFe packs load test just like normal batteries?
No matter that they aren't true A123s. You cannot load test them ,especially with 1a. 1a. isn't even enough to tickle them. Charge them, make one flight, then charge them again noting how many Ma. you put back in. Once you know this you can calculate how many flights you can safely make before a recharge. As a rule, I do not run mine below 50% of capacity which leaves a large margin of error. They only take 15 or so minutes to recharge anyway.
4*60 11-11-2012 01:25 AM
I agree with above.  I use less than 100mah in 3 flights on 5 standard servos in a 4*60 on HobbyKing 1100 LIFE rx packs at $4 each so I would use the Hobbico's for a few years and then buy the HK's and use them for a few years.  If they ever weren't up around 6.6 after charging I would replace them.   At $4 before shipping and with them considered non-toxic don't keep them too long.  :)
KW_Counter 11-11-2012 06:37 AM
Since LiFes voltage drop very quickly when they get below their
nominal voltage (3.3 v/c), I stop flying them when they get to 3.2 v/c.
I am using LiFes in my transmitter, I stop/recharge at 9.8 volts.
They will stay at 9.9 for quite some time.
This is also true of LiPos.
Good Luck,
KW_Counter
countilaw 11-11-2012 08:16 AM
I would recommend Hobbico's batteries and I think you will find them of excellent quality. Hobbico like Tower demands a higher quality control standards and have a fantastic customer service reputation. If you ever get a bad battery or one that doesn't stand up your quality, help is just a phone call away.
Frank
K-Bob 11-12-2012 05:22 AM
True, authentic A123 packs will outlast and outperform generic LiFes all day long. They are available from several trusted vendors at very reasonable prices. TaildraggerRC, WrongwayRC and NOBS are just a few I have used with great results. I'm not going to risk my planes to save a few bucks on HobbyKing anything.
raptureboy 11-13-2012 06:47 AM
+1 taken from Hangtimes site-<p class="MsoNormal" align="center" style="text-align: center; margin: 0in 0in 0pt"><font size="3"><font face="Arial"><span style="color: black">Q: What's the difference between A123 LiFe packs and LiFe PO4 packs like Hobbico's LiFeSource&trade; packs?</span></font></font></p><p class="MsoNormal" align="center" style="text-align: center; margin: 0in 0in 0pt"><font size="3"><font face="Arial"><span style="color: black">*</span></font></font></p><p class="MsoNormal" align="center" style="text-align: center; margin: 0in 0in 0pt"><font size="3"><font face="Arial"><span style="color: black">Two big differences. First, A123's patented 'Nano' plating technology.. at a molecular level the negative plate material stands like a shag carpet rather than laying 'end-to-end'. This produces an incredible amount of surface area gain for A123's negative plate and it's why A123 can tolerate immense current loading without voltage sag. Another benefit to the nano plating technology is a huge increase in cell life. All stored energy systems consume negative plate over time.. with 100+ times thenegative plate surface area generated by any competitors plating processthe lifespan of the A123 cell is extended immensely. Next, A123's arealuminum cased cylindrical cells withwelded alloy end plates and towers like a Nicad cell. This enablesa rugged welded strap packassembly system (like Nicads) that is exceptionally robust and veryresistant tovibration andhard knocks.TheLiFeSource&trade; packs are built with wafer stacked'bag' prismatic cells.. like LiPoly. And, like LiPoly, they are fragile, thecell link tabs are very thinalloy stripsand the entire assembly is as a result susceptible to rough handling and vibration. Further,the prismatic cellsand their tabbing system are unable to handle anywhere near the current loading the A123 system can tolerate with ease.</span></font></font></p><p class="MsoNormal" align="center" style="text-align: center; margin: 0in 0in 0pt"><font size="3"><font face="Arial"><span style="color: black">*
But from an AMERICANCOMPANY!These guys aare based in LI,N.Y right at ground zero of Sandy. If your plane means something then your battery should also. http://hangtimes.com/index.htmlThey could use our help right now.</span></font></font></p>
pilotpete2 11-13-2012 07:43 AM
+++++1
Pete
trax de max 11-13-2012 08:49 AM
Hasn't A123 went into liquidation now.
Goldenduff 11-13-2012 02:41 PM
Bought by Johnstone controls I think?.....
BarracudaHockey 11-14-2012 06:14 AM
That was the car battery division.
Hobby, tools, military, has been unaffected.
My sources are now selling the new 2500 mah A123 packs and cells are available aplenty
