Onyx 230 low charge current
Hey guys,
I am having some issues with my onyx 230 charger. I have a 3s 4800mah lipo battery. I was running it one days as usual until I noticed my speed control began to limit my rustlers speed, so i drove the car in and turned it off. About 3 hours later I went to put it on the charger and i was having troubles charging it. I have my charger setup as follows: Lipo 4800mah 4.8a charge rate 120 minutes I have never had any issues charging it with these settings. However when I go to charge it now, these are the readouts I am getting. CHG cur. 0.01a IN Volt 12.27Vi CHG Volt 9.78Vo Any idea why my charge current is so low? Would this be a battery or charger issue? Any suggestions would be greatly appreciated. -David |
RE: Onyx 230 low charge current
What's the voltage on the battery? I might be charging at a really low rate in order to get the voltage above the minimum before it starts to charge at 4.8amps again.
Have you ever balanced your battery? |
