What's this tube for?
OK
Got my first "Big Boy" plane recently, an Aeroworks Yak 54 (.60-.90). Much different than my three previous planes, Tower Trainer, GP Easy Sport, and H9 Ultra Stick. I'm wondering about what appears to be a pushrod tube that starts about mid fuselage, runs to the tail, and exits just ahead of the tail wheel mount. I have no idea what it's for. Also I'm powering it with a Saito .82 - The exact engine used in the manual as the example for the "4-Stroke Installation" section. I'm worried that it will be underpowered. Don't really care about speed, but I do want it to be able to climb vertically. I'm running a 13 x 7 on the Ultra Stick. Perhaps I'd benefit from a 14 x 5 or a 14 x 4W on the Yak? Thoughts?
OR
RE: What's this tube for?
ORIGINAL: jknox
Got my first ''Big Boy'' plane recently, an Aeroworks Yak 54 (.60-.90). Much different than my three previous planes, Tower Trainer, GP Easy Sport, and H9 Ultra Stick. I'm wondering about what appears to be a pushrod tube that starts about mid fuselage, runs to the tail, and exits just ahead of the tail wheel mount. I have no idea what it's for. Also I'm powering it with a Saito .82 - The exact engine used in the manual as the example for the ''4-Stroke Installation'' section. I'm worried that it will be underpowered. Don't really care about speed, but I do want it to be able to climb vertically. I'm running a 13 x 7 on the Ultra Stick. Perhaps I'd benefit from a 14 x 5 or a 14 x 4W on the Yak? Thoughts?
OK
ORIGINAL: OkadaKeisuke
jknox,
Is it a pushrod tube for a steerable tail wheel? The pushrod would link to your rudder servo. Just a guess.
~Noah
jknox,
~Noah
That's all I could think of also, but it came with a very nice tiller type tail wheel
ORIGINAL: oldtyme
It's a tube to run your receiver antenna through to keep the install clean. If you have a 72mhz receiver then route your antenna through the tube. If you have a 2.4ghz receiver then just ignore it.
Ahhh,Now that make sense.Thanks all.
Just remember this... if you DO run an antenna for 72 MHz through that tube, make darned sure you put a "strain relief" or a knot or something at the outside end of the wire so that it does not snake back into the fuselage and into a bundle.. vibration will do this and cause you all sorts of problems.. most of them very short term and ending up in a pile on the ground.
CGr.
CGr.
