If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
  1. #26
    Join Date
    Jul 2011
    Reedsburg, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Four Stroke Engine in Tower Trainer .60
    I had 4 stroke engine right from the beginning. No problems operating any of them. I have a couple Magnums and OS, they all start and run great. And they are easy on fuel and the ears.
    I had a few crashes, never broke an engine...
    So if your plane can handle the extra weight, I'd use the 4 cycle. I don't see why they would be harder to operate. Make sure you use the right prop nut with a jam nut, and the worst you will see is that if the engine backfires, the prop comes loose, but does not spin off.
    Also - use an electric starter, do not hand start it, unless you know you engine well. As a beginner - keep you hands away from the prop.
    Same thing for 2 stroke engines.
    When it come the engine repairs - yes, the strokes are a lot easier to work on. Less parts, less costs and less efficiency.
  2. #27
    rowdog_14's Avatar
    Join Date
    Sep 2005
    Austell, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: OliverJacob
    x2
    THE T.R.U.T.H
  3. #28
    Join Date
    Feb 2007
    Dearborn, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you decide to go with the 4-stroke, I recommend that you use an aluminum spinner for safety in case of a backfire.
    Access to a tachometer for tuning is also recommended for a 4-stroke, can't go by ear to get peak rpm.
    Content, but not Complacent.
  4. #29
    budchugger's Avatar
    Join Date
    Sep 2005
    navarre, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i used a Saito 100 in mine when i stated
    The only thing that\'\'\'\'s supposed to drop out of the sky is bird ****
  5. #30
    jmcowart's Avatar
    Join Date
    Aug 2011
    Douglasville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the suggestion. I have a Tru-Turn aluminium spinner and back plate. I haven't been able to get it to fit yet. Ip;urchased the adapter recommended by the Tru-Turn Company and it didnt fit. Wouldn't tighten enough to snug down the spinner.
    The company sold me another, shorter, adapter and I tried that as well. It wouldn't fit either.
    After the next call the Tru-Turn they sent me a no charge adapter and Ihaven't had a chance to try it out yet.
    I don't have much confidence in them as of now. Their web site sounds good and the self-proclaimed quality they push sounds good, but my results have been both expensive and frustrating. Nothing has worked as yet.
    For others, if you are using an O.S. FS-95V, find another aluminium spinner as Tru-Turn hasn't got their act together on this engine yet.
    Mike.
    Mike
    Douglasville, GA
  6. #31
    Join Date
    Jan 2003
    Spring Hill, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Are you using the propeller washer?
    Work is what I do for the love of it. A job is how I pay for it.
    Please visit AirfieldModels.com
  7. #32
    jmcowart's Avatar
    Join Date
    Aug 2011
    Douglasville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, prop washer that comes with the engine, then every prop nut and jam nut combination possible provided by either O.S. and/or Tru-turn. I will probably end up using the little solid aluminium spinner by Du-bro.
    I will try the new adapter sent by Tru-Turn tomorrow and I have my fingers crossed that will secure the 2.5 aluminium spinner by Tru-Turn.
    Mike.
    Mike
    Douglasville, GA
  8. #33
    carrellh's Avatar
    Join Date
    Mar 2003
    Garland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Truturn spinners are as good as any other but getting the right combination of spinner/nut/adapter can be frustrating. Trial and error does get expensive. The 'ultimate' shape is longer than some of their other designs.
    http://www.truturn.com/Spinners/By_S...e_ultimate.htm
    Unless you need the nose weight, just use the plastic spinner that came with the arf
    - Carrell
  9. #34
    JollyPopper's Avatar
    Join Date
    Oct 2002
    Mountain Home, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a Tower Hobbies .60 trainer, and it is a superb airplane. Mine has a strong .61 in it. Would I trade that strong .61 for a 90 to 115 size four stroke of just about any brand and install in that airplane? You bet your bippy.
    \"In theory, there is no difference between theory and practice; In practice, there is\"
    Intolerance is not to be tolerated
  10. #35
    Join Date
    Feb 2006
    Arroyo Grande, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The great plane aluminum back, plastic cone spinners are a good choice. I'm not a fan of the plastic back spinners as they cursh under a very tight prop, and Ireally tighten mine up. they also provide a crush zone in the event you land nose first. They have saved a couple of my engines.
    http://www3.towerhobbies.com/cgi-bin...?&I=LXBMY9&P=7
    This is an example, they come a a number of sizes and colors. No spinner nut to worry about, just the nuts that came with the enigne. They are easy to carve out to fit a prop, a #11 Xacto knife is all you need.
    Don
  11. #36
    scooterinvegas's Avatar
    Join Date
    Mar 2010
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had a Thunder Tiger 91 four stroke on a 60 size trainer and it flew fine. Not under nor overpowered. Wait, what was the question?
    Maybe I should just take rubbing alcohol with me to the field and rub the props down before starting any of my planes!
  12. #37
    Join Date
    Jun 2009
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Probably totally unrelated, but I have the Tower 40 trainer and I put a 52 4 stroke on it, and it is definitely a fun airplane. very short take offs, lots of flight time as I can fly at less than half throttle for at least 20 min flights, great for students to fly with as it will slow down quite nicely when needed, but has the added punch to get out of trouble easier, and definitely love the looks and comments at the field about having a 4 stroke on a trainer.
    If your patient getting it all set up and dialed in, you will love that 60 trainer with a 95 4 stroke in it.
    Good luck and happy flying......
    Remember: What goes up MUST come down. How it comes down is purely up to you.....
  13. #38
    mike109's Avatar
    Join Date
    Jul 2004
    Dubbo, New South Wales, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    G'day
    Way back in 1992 I put an OS 48 Surpass in a Thunder Tiger 40 size trainer. All the experts told me it would not work but when they flew the plane, they were immediately converted.
    Four strokes will happily run at part throttle all day, are economical and best of all, quiet. They are not hard to handle and rarely deadstick. As a result, I have been using them in trainers ever since. They are particularly good for older learners who seem to appreciate their good pulling power at lower speeds.
    They can be damaged more in crashes than two strokes but I have always been able to repair them and with buddy boxes, crashes are rare these days.
    At the present time I have a range of trainers and only one has a two stroke.
    Mike in Oz
    \"I just had no control. Must be the radio.\" Club Saito #597 Kadet Brotherhood #66
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
