Omega fuel question
CA
Omega fuel question
okay, yet another fuel question.
the guy at the hobby shop gave me omega (castor/synthetic blend...pink stuff) fuel for my GP42 motor.
i cant find any real info on what's in it. The only info on the label says that it contains methanol, nitromethane and a non petroleum lubricants, but gives no percentages. It says 10% on it, but that's it. Is that amount of nitro that's in it?
there is not info on the bottle or on their website to show how much castor oil is in the fuel. i just wanna make sure that its got the manufacture's minimum requirement of 20% castor....
thanks guys!
thanks guys!
CA
RE: Omega fuel question
cool. thanks fellas!
after running a synthetic in the motor, is it possible to run anything that is simply methanol and castor without the sythetic?
because i know that after running synthetic oil in a car motor, the residue left by the synthetic oil, will keep the conventional from lubricating correctly.
Morgan Fuels (Omega, Cool Power, etc) started rebuilding their web site quite a while back and all they've managed to do is make a link to Facebook. I'm not sure how that is considered 'progress' but I'm sure it is.
The old site had all of the percentages so you knew what you were getting. As others wrote, total oil is 17%. The ratio is 70/30 synthetic to castor so you have 11.9% synthetic and 5.1% castor.
I've used Omega, Cool Power, Wildcat, Power Master, Ritchs Brew, and Magnum. All seem to run the same and they all keep the engines lubricated.
My Feedback: (7)
ORIGINAL: mach2
thanks guys!
thanks guys!
Happy landings.
ORIGINAL: mach2
This is incorrect. Putting conventional in a car that's lived on synthetic won't harm a damn thing. The conventional will lubricate just fine, up to it's own natural limits. The issue arises when you take a car that's lived a long life on conventional and stuff synthetic in it. Conventional motor oil leaves deposits and residue on the engine internals, and on a high mileage(150K+) motor this residue is often all that's keeping the main seals from leaking. Put synthetic in it and the detergents in that oil that clean out the oil goo that's keeping the motor sealed.
This same thing will happen with a glow engine as well. The castor oil does the same thing as the conventional oil in a car engine. Run an engine on a castor-heavy fuel mix for a couple of gallons and pull the backplate off. You'll see castor goo everywhere. Run a gallon of synthetic-only fuel through it and that castor goo will get flushed right out, and if that engine is old enough it will start leaking oil out the front bearing. Luckily you can seal it back up by just feeding it castor-heavy fuel again, eventually the goo will build back up and it will stop leaking.
ORIGINAL: mach2
...is it possible to run anything that is simply methanol and castor without the sythetic?
I have a LA .46 that was always run with an OS spec fuel I mix myself, and its still got a ferocious ABC "pinch" at TDC even after about 5 hours of running.
For his whole life, Duke Fox was a proponent of castor oil for his engines, and they'd last for many hundreds of hours when fed what he said to feed them.
