eflite retracts 60-120 size
Reply
Old 01-03-2012, 09:13 PM
nrad2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default eflite retracts 60-120 size
I'm planning to put retracts in my new kit Top Flite P-51 1/7th scale. Has anyone here installed an E-Flite electric retracts 60-120 size for a RC Glow Plain? I'm worried about the vibrations the nitro engines can produce. Can the retracts move the extra weights, such as; Robart Robostruts? And finally, how is the construction and the build of the e-flite retracts? Do they operate reliably?
Jimmy
nrad2000 is offline
Old 01-03-2012, 11:27 PM
kiwibob72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: eflite retracts 60-120 size
There are a number of folk out there who have used them in build threads on gas or nitro planes, all sound happy, with not a single complaint I've seen.
I'd be using them if/when I get around to building their 60 sized P47 kit.
kiwibob72 is offline
Old 01-04-2012, 04:45 AM
bingo field
bingo field's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used them on my AT-6. I felt they worked just fine. They don't, however, hold up to being removed from the airframe once installed, by being pulled out by an Ash tree. I had the 120 sized AT-6, and the Zenoah G26. They held up much better than the original pneumatic retracts that the plane came with. They are simple to install, and I tested them at least 100 times on the ground to see how consistently they would cycle, and checking battery drain. I had no issues with operation of the retracts, and using the same 2000mah battery as on the receiver, I didn't feel that there would be any issues powering them. This was by observation using a Voltwatch during operation. While they aren't cheap, I give the reliability factor a +10.
bingo field is offline
Old 01-04-2012, 04:58 AM
bingo field
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kiwibob72
I built that kit and put Robart mechanical retracts operated by JR retract servo. You will save yourself about 6 hours by putting them in instead. You will have to learn how to land this. You have to fly it right to the ground, and stall it on the ground, to avoid nose over. When you do it correctly, it is a thing of beauty. When you go through taxi testing is when you figure out how much nose heavy it has to be to fly. If you shift the weight too far to the rear, it will become very elevator sensitive, and still want to nose over. Giving it extra throw to taxi with is helpful, just remember to turn off the high rates once you start to roll out, you don't need all that throw in the air.
Old 01-04-2012, 10:50 AM
kiwibob72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bingo field
Nice feedback on the TF P47 there bingo field, I have a H9 P51 60 Blue Nose that I'm starting when I have time next week (powered by a DLE20) .... that baby should huh like there is no tomorrow!
That said, I will be adding an 'intermediate' plane into the mix before flying that specific plane as I want to get a few things down pat first (insurance from my trainer that got squashed in the Dec 23rd 6.0 quake will come in quite nicely I think) [:@][:@]
Old 01-04-2012, 12:50 PM
landeck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kiwibob72
I have just installed them in a TF P-47 60 size plane. They went in very easy. I am using them with these struts:
http://www.rcskylite.com/products/40...underbolt.html
Some people have had problems early on but Horizon replaced the problem ones. I am not ready to maiden my plane yet and will not until spring. I will be reporting on how they work out at that time.
Bruce
landeck is offline
Old 01-04-2012, 09:55 PM
nrad2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, I'll give the E-flite electric retracts a try. Will order them once I get started on my P-51 this weekend.
nrad2000 is offline
Old 01-22-2012, 12:26 PM
nrad2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finished mounting the eflite retracts. Surprised how robust it is. Should be able to take a beating. I should have my top flight p 51 done in about 4 weekends.
nrad2000 is offline
Old 01-22-2012, 12:44 PM
flyntruk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
E-flite retracts for a P-51 .... Look into the 85* retracts For the diehedral in the wing
flyntruk is offline
Old 01-24-2012, 05:16 PM
nrad2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got the 85deg. Its close to perfect. Plenty of power to lift robostruts and 3 1/4 tires. Once this project is done I'm panning to build the mentor with eflite tri gear.
nrad2000 is offline
Old 01-25-2012, 10:53 AM
kneewhack
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone think they would work in an ESM SBD-Dauntless. This plane weighs about 14 pounds. The specs state they will handle up to 15 pounds
, but I'd like to hear from someone who has used these in an airplane of this weight. Most other air or elec retracts available cost as much as the entire plane!
Mike
kneewhack is offline
Old 03-17-2012, 09:12 PM
callide
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the 90 degree e-flite retracts and should of got the 85's because of the dihedral in the wing, is it possible to adjust the linkages perhaps to get 85 degrees in the retract without having to re-order the 85's
callide is offline
Old 03-19-2012, 08:02 PM
flyntruk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
  I'm also using e-flite retracts  in my kyosho spit 90 . this plane has a 73 ws . i'm using the factory struts from the plane since the legs  have a differtent angle to them . But I don't think I'll have any problem , as long as I don't weifgt them down by using a different wheel . I did add some bracing to the mounting area  of the LG .
flyntruk is offline
Old 03-21-2012, 02:35 AM
Hisham
Hisham's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
guys,
where can i buy the eflite retracts size 1.20?
thanks
Hisham
Hisham is offline
Old 03-24-2012, 03:47 PM
mustangman177
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.e-fliterc.com/Electronics...ndingGear.aspx
mustangman177 is offline
Old 03-26-2012, 06:37 AM
hobbychina2010
hobbychina2010's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
we have the Air Retracts 60-120 kit, http://store.hobby-china.com/Wholesa...racts_c23.html
hobbychina2010 is offline
Old 04-15-2013, 09:56 AM
biffster55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
KiwiBob
I have a P51 Bluenose that I'm going to install Eflite retracts. The mechanical ones are a pain. Which Eflite retracts are you using? Any mod to the wing for install? Thanks!
biffster55 is offline
Old 04-15-2013, 11:09 AM
kiwibob72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: biffster55
KiwiBob
Sorry, I stayed with the Mustang, and never got the TF P47 kit ... though my Dad did.
My understanding is that the 85degree 60-120 size mains (re wing angle and plane size) are the way to go (refer to the above comments as to how one person with them found their performance).
There are also a lot of 'scale' landing struts out there there that will work well with them. Just refer to the E-flight spec's for strut hole size, then find the right diameter and length scale strut to suit.
Old 08-20-2013, 04:32 PM
chuckk2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
About a year ago, I had problems with the E Flite 60-120 85Deg retracts. Turned out that they were drawing much more current that specified.
After a fair amount piddling around, I managed to reduce the peak current to an acceptable level, although it was still a bit higher than the spec.
We tried more than one set, and those tested at the time all had the same issues.
Moving forward, I had occasion to purchase another set, along with some other stuff.
The new set was checked immediately on receipt. Lo and behold, the new set actually met the current spec.
What is the basic difference? For one readily noticeable difference, the new set is a bit quieter in operation, and somewhat slower.
Perhaps the motors were changed?
chuckk2 is offline
Old 08-25-2013, 05:43 AM
Tragedy Trousers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might want to look at wingspan retracts if your looking on using electric retracts. Im using them in a hanger 9 P51. Not one problem after a year of flying with them.
Tragedy Trousers is offline
Reply
Display Modes
