NEW TO GASS'Rs
NEW TO GASS'Rs
Hi Gang:
I'm new to GAS (MoGas) engines. I will be building a 4-120 Bipe and would like to get some opions on what make and size engine would fit this bird.
Could you also give reasions why you make your particular suggestion.
Thanks Gang,
Barry
Thanks Gang,
Barry
RE: NEW TO GASS'Rs
The best gassers out there in the 50CC, 30CC would be DA, DL, DLE....good reliable engines. everyone stocks them so it is easy to get parts and support...
Since you're new to gassers please use an optic kill switch......it will shut off the engine in case of a power failure on the airplane...it has a small section of fiber optic to help reduce noise ( interference ) from your ignition...plus it gives you an additional way to kill the engine from your transmitter
OR
RE: NEW TO GASS'Rs
ORIGINAL: N52961
Hi Gang:
Thanks Gang,
Barry
Hi Gang:
Thanks Gang,
Barry
Here's the link: http://www.rcuniverse.com/forum/forumid_142/tt.htm
NJ
RE: NEW TO GASS'Rs
ORIGINAL: N52961
Hi Gang:
Thanks Gang,
Barry
Hi Gang:
Thanks Gang,
Barry
GreenBrook sells RCGF. Both places have been there for a long time
My Feedback: (-1)
RE: NEW TO GASS'Rs
Go look in the gas engine forum, you don't even need to post a question, just read. At this time the DLE is king. A lot of bang for your buck. So far DLE is staying on the top of the heap the longest. Other cheap gas engines have come and gone in the blink of an eye. I run RCS, Brison and Zenoah but if I needed a new gasser I would walk right up to the DLE counter.
