My friend wants a cool looking starter plane.
Warbirds are hard to fly as a beginner.
My point was that the tail dragger taught me to use rudder, not that a beginner can pick up a warbird right after a few flights on a tail dragger, I guess my wording left you to believe that was what I meant.
All training should be on a four channel plane. Three channel planes are a waste of the teachers time. It is your time to waste so that decision is up to you.
my 2 cents.
This is certainly not an attack on your abilitys at all you see the ability to operate a buddy system safely has nothing to do with how good a pilot you are. Many times the hot shots make terrible instructors and simply cannot stand there and hold that trigger. And I am not even talking about the most important parts of instruction such as the fundimentals of instruction along with the anaylisis and performance of manuvers. What most first time instructors will do is stand there and fly the sticks without ever letting go of that trigger as the students airplane spins into the ground.
When I introduce someone into the joys of flight instruction (they do not have to be long time pilots or hot shots) I always do it on the buddy boxs with them using the hot trigger. This going through typical screw ups. This always takes more than just one flight.
Problem is you are asking if you can perform as an instructor (a performance which does indeed carry certain responsibilities) cold turkey and with an inappropriate trainer to start with?
The chances for success in this endeavor no matter where or what you fly are slim.
John
When I started flying I had my fair share of crashes with Balsa planes. Literally 3 planes up 3 planes down and back home for some time consuming fixes. It's not so much what plane is a good one to be instructed on it's what plane is good and will also survive all those Post-solo mishaps you are bound to have when you're on your own flying without your co-pilot. I didn't get a Multiplex plane until I needed some electrics for a local "quiet" field and wish I had known about Multiplex while training.
What I have found is the Multiplex products are very, very durable. I have crashed my Minimag many times and even cart-wheeled down the runway with hardly a scratch. Just last week a new guy turned on his radio on the same channel (didn't even check for his pin) and I literally fell out of the sky at about 50 feet and suffered only a broken prop. With reg CA a fix can be made most times instantaneously at field and you could keep flying. More time flying is the key your friends success. Quick turn around after the inevitable crash means everything. You know get back right back on the horse...
I have 3 Multiplex planes two are "trainer" types - a Minimag and a Magister and although I don't fly the big one much I fly the the Minimag just about every time I go out. It is a hoot to fly, not really a trainer with hotter brushless and 4ch but as a 3 channel it was very tame a great flyer and even good wind plane... Magister is a *****cat - many who have flown it are very impressed with how stable it is.
In comparison I have a couple of Durastiks known for being the "Indestructible" trainer. Yes it is truly a durable plane but hardly a trainer with that flat wing and I have crashed and done considerable damage over the years but it does survive and can be rebuilt most of the time. Definitely not indestructible though.
Building a wood kit is a great pleasure but as a first plane that most certainly will crash it can be discouraging. Why not start building the kit or ARF while learning on a cheap used beater or a durable foamy.
Get a Multiplex... Possibly look at the Cub or Mentor and don't let the foam design stop you they are well designed, they fly like intended and very, very durable. Many can be enhanced easily with hotter brushless motors and increased throws for later. So IMHO not a dead end either.
More flight time = Success
Just my 2ΒΆ
Tom
<o></o>
A cool plane for a beginner [Nimrod] is a plate that looks just as good going out to the field as when coming home from the field. The only time a plane should be in a plastic bag is when it is coming from the Hobby Shop.
<o></o>
Take your 20 years of experience and smack him up-side the head with it.
Tell him to give you $200 so when he plants the plane 6 inched into the ground it will REALLY hurt. Since he does not want to listen to you he must be rich or dumb or both.
<o></o>
He would like an electric.<o></o>
>>>Electric is GOOD – Nothing wrong there.<o></o>
He would like to build a balsa plane from a kit.<o></o>
>>> Building is GREAT! He will learn, and invest TIME which cannot be returned. >>>So maybe he will listen to you.<o></o>
He would like to keep it smaller than a .40 size kit, more like a .1-.2.<o></o>
>>> WRONG – WRONG – WRONG – BIGGER IS BETTER. You want a plane that is >>>stable. Easy to see. Different pattern on the Top and Bottom of the wings.<o></o>
>>>I would recommend nothing less than a .40 or even a .60.<o></o>
>>>I made the SMALL mistake years ago. It took me a LONG – LONG time to learn.<o></o>
>>>Take my 40 Years of R/C experience and save time and money.<o></o>
He would like a plane that doesn't look like a lame trainer.
>>> Then have him build a WWII Piper Cub as a L19 in military colors and with <o></o>
>>> WORKING Bomb Drop.<o></o>
>>> Or do a real fancy color scheme.<o></o>
<o></o>
>>> Also, Building a tail dragger is an easy build since you do not have to mess around with all that linkage going to the nose-wheel. The only down side is a bad landing results in a busted prop. Easier to replace a prop than rebuild the nose of a plane. Shorter time also.
<o></o>
Barry
