LT40 Finally Flies!
KS
LT40 Finally Flies!
Well,
Labor day dawned bright and blue with low temps and little wind. I live in a small rural town, and have but one instructor. He called up and said, "lets go". Loaded the plane. We did a full tech inspection. Gasses they plane and he took her up. Checked it all out and the only 'problem' was with power applied she wanted to climb. Ease of the power and she was fine. He wrung her out good, and pronounced her airworthy. Second tank and up she went. This time, I got stick time. Reality-check. This is more difficult than it looks. LOL. Well, needless to say after that I was shaking a bit. Third tank and after he took it off, I flew most of the tank. Getting a bit better in maintaining altitude when turning, etc. He landed it and we called it a day. Boy am I jazzed. It flew well, I got stick time. And it went home in the same number of pieces.
I'm hooked!
I'm hooked!
LT40 Finally Flies!
I've been flying the LT-40 for a grand total of two months now and I have to say that I love it. It's been such an easy and gentle trainer to me that I'm now starting to get more confident with it and am flying it around the pattern inverted - it's wonderfully docile and very predictable.
Have fun with yours, and congratulations on the first flight! If you think THAT was fun, just wait until you solo!
Neil.
LT40 Finally Flies!
The LT-40 is a great trainer; so is the LT-25, by the way. They both tend to climb under power, it's part of the characteristics of a flat bottom wing. You can reduce the wing incidence, but it's not that big a deal once you're used to it. They both land great if you bring it in slow enough. I almost prefer the LT-25 for its light weight and easy transportability, also an easily built kit.
LT40 Finally Flies!
I have the O.S. .46LA on mine, but if you're going to get an O.S. engine I'd recommend the .46FX instead. The LA develops enough power to fly the plane, but there's none to spare above and beyond that.
CO
LT40 Finally Flies!
I have a Magnum XLS-46 on mine and it has done great. The OS engines are lighter and some guys have had to add weight to the nose.
Anyway, you can't go wrong with the OS.
I've been flying my LT-40 for three months and the time has come to get serious on#2 (a Sig 4 Star 60).
LT40 Finally Flies!
Flying great though, despite the needed weight up front
love the LT 40
hey I learned on a sig lt40 also super easy trainer !! I had a OS 40FX to start with on it but used the 40fx on another planne later on ! now the LT is being used again to teach my daughter to fly and I have a TT 46 pro on it and its lots better . I really like the setup now running a APC 11X4 prop. off the ground faster and lotsa power to pull out of not so good of approches!!
Thumbs up to ya on your flying !! :thumbup:
