4 Stroke Throttle Linkage
CA
To hook up the throttle on my OS 4 stroke I need to pass the throttle and then
bend the wire back 180 degrees to the carb.
I understand this is a common situation with 4 strokes.
I can either put 2 90 degree bends in the wire or use one curve back.
Which is better and why?
KW_Counter
KW_Counter
RCU Forum Manager/Admin
My Feedback: (9)
RE: 4 Stroke Throttle Linkage
I've used them both ways but my personal preference is to bend them in curves. I feel this works better as it gives a little bit more flex as the throttle hits its limits. But that is my personal preference and either way will work just fine.
Dubro makes a product that also takes care of this problem
You can buy from them, or you can actually make the same thing using spare parts. I have actually done that a few times and it works just fine.
Ken
CA
Ken,
Thanks. The DuBro device looks nice but a lot of work.
Especially compared to bending wire.
KW_Counter
KW_Counter
I have three 4 strokes and have used throttle cable on them instead of trying to loop and bend wires. Works great with no binding, and can be right up against the FW.
a small smooth bend is also less stressful on the wire than a tight 90 degree bend. Bend in tight 90 may crack wire and cause future failure. Even Z-bends on control surfaces occasionally crack.
