Guanli pby throws
Reply
Old 09-24-2012, 06:50 PM
left seat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Guanli pby throws
I just recieved the Gaunli PBY and the instructions are really bad. However, I had one before, crashed it, and I figure that the main reason for the crash was because the control surface settings were not set properly. Since the instructions for the model didn't specify what the throw settings were I used the throw settings from the Great planes PBY. I don't want to crash this one also. Can anybody give me an idea of what the throw settings for the control surfaces are supposed to be? High and low rate setting info would be very helpful. Thanks
left seat is offline
Old 09-24-2012, 07:11 PM
Charlie P.
Charlie P.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Guanli pby throws
Having no idea about that model here are some thumbnails:35° is 3-D rates on any surface (after that they just stall and you won't need anything near that on a PBY), so low of 12° and regular of 24° will get you ballparked on most airframes. Works for rudder, elevator and ailerons.
Charlie P. is offline
Old 09-24-2012, 08:30 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What Charlie said on ballpark figures is pretty good information also you need the make sure the airplane is balanced at 25%. Since a PBY is a double tappered wing on the outboard panels and straight chord wing on the center panel You can treat it as a straight chord wing for balance purposes.
So all you need to do is measure back from the leading edge one quarter of the distance between the leading and trailing edges in the center section. Then simply do what ya gotta do to make it balance at that point.
John
JohnBuckner is offline
Reply
Display Modes
