DX8 Servo Problems
DX8 Servo Problems
I have the DX8 transmitter with an AR6200 receiver. My airplaneis setup with 2 servos on the elevator. One operates normal and the other justflips up and stays there when I cut the plane on. There is no movement eitherway once it has power. The one that goes up is in the gear port. How do I adjust this servo tothe other one to function correctly?
You need to assign the gear channel to the elevators if I remember correctly on a Futaba 1 and 6 is ailerons so 2 and 8 are elevators. Not sure if it's that way with JR
On spectrum you can only use a aux channel, not gear. If you are running a duel elevator 1 goes in elevator and the other in aux 1 port. In the basic en set up window you need to go into wing configuration and change to duel elevator. After that then you go into servo set up; scroll thru all of the options, you will have L elevator and R elevator, one of them you will have to reverse one of them.
Hi!
All servos work with a Spektrum /JR radios and it's the same with all other radio systems too (Futaba, SANWA, Hitech, Graupner/JR)! Analog or digital doesn't matter.
