Sport plane Power Setup Query
WV
Hi All
I have recently purchased the Nemesis ARF 1560 mm from Hobby king.
with it i purchased the recommended accessories:
[h=4]Turnigy dlux 70A SBEC Brushless Speed Controller w/Data Logging[/h]NTM Prop Drive 35-48 Series 900KV / 815W
[h=4]Turnigy nano-tech 4000mah 4S 45~90C Lipo Pack[/h]Turnigy 12x8 Prop
[h=4]HK15288A Analog BB/MG Servo 51g / 9kg / 0.20s[/h]
After setting her up i measured the motor current with the throttle set to 50 % ( the prop was connected and i held the plane tight).
I measured the current with an AC clamp on meter on one of the three wires going to the motor.
the current was 60 A. Am i measuring this incorrectly ? as i am scared that i will fry my ESC if i go too 100% throttle.
should i rather measure the DC current from the Battery ?
Secondly, i am running 5 servos off the BEC of the ESC listed above . is a 3 A BEC sufficient ?
Any help would be greatly appreciated as i would like some clarity before i take her up.
many thanks
Bob
many thanks
Bob
WV
Hi All
i was using a "no name brand" clamp on meter. hence i queried the measurements.
I compared it to a Fluke clamp on and got the following results at 100 % Throttle:
motor phase current = 28 A
DC current from battery = 58 A
these results seem much more realistic.
i also measured the BEC current with all servos moving, and it amounted to a max of 1.5 A
and the voltage stayed at 5.6 V.
all seems fine. Problem solved.
many thanks
Bob
many thanks
Bob
Moderator
Yes, it does sound like you are ok. The current will go down a bit in actual flight since you won't be holding the plane back from moving then. The on ground test gives you the worst case scenario for amp draw.
BTW: You may want to measure the BEC current while putting a LOAD on the servos.
In other words restrict the movement a bit of at least two control surfaces as you move all of the servos at once.
That gives you a more realistic worst case.
Standard high torque servos can draw as much as 2 amps each, particularly the digital ones.
