Sig Jenny build
Sig Jenny build
So after trying to figure out what I need I decided to just ask!
heres what I don't understand yet as a newb to electrics...I have a sig jenny and need to find a battery and esc to go in it...
The manual says to use a 6 cell 720AAA mAh Nimh square pack, and a 5amp esc...
- is it safe to use an esc with a higher amp?
- is a 7.2v 800mAh ok to use with the stock 180 motor
-I have a spektrum ar600 receiver laying here as well...is that too heavy you think?
Any guidance would be helpful!
Moderator
one important thing to remember IF you're using the stock motor... that is a brushed (NOT brushLESS) motor... you'll need to find an ESC designed for brushed motors.
yes, it's fine to use an ESC with a higher amp rating, but not one with a lower amp rating.
your ar600 should be just fine, it should not be too heavy.
and yes, the 7.2 volt lipo should also work fine, but again remember to get a brushed ESC designed for Lipo batteries.
good luck!
good luck!
Ok great! That's what I was hoping to hear!...so just watch the ESC as I need it to be brushed.
Thank you for the info and response, I didn't want to risk burning something out my first flight!
