Reload this Page >
I need help with setting up flaps on ultra stick 40
Reply
Old 05-23-2014, 08:25 AM
rcworld2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default I need help with setting up flaps on ultra stick 40
I need help with setting up flaps on ultra stick 40 ok i set it up for just plan old flap not flaperions or what ever they call them. I'm new to flying ive mastered my trainer now i want to move up to this plane.
me and my trainer took it up today and it flys great but as soon as you put the flaps on the planes nose just lifts up. now is this normal?
i have the flaps set on a three way switch off half and full which is 22 degrees per manual.
i use a futaba 8fgh super radio
so what can be done to help this?
rcworld2000 is offline
Old 05-24-2014, 08:21 AM
Pylonracr
Pylonracr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is common for a stick to climb with flaps. Just mix in some down elevator with flaps. Go a couple of percent at a time until you get no pitch change with flaps. Check it up high in case things do not go as planned.
Pylonracr is offline
Old 05-24-2014, 10:16 AM
rcworld2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok I'll have to read up on how to do the mix
Old 05-24-2014, 10:18 AM
bikerbc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is very common for a plane to pitch up when flaps are applied . Even with full size you must trim in down elevator. I am not familiar with your radio but there should be a section in your manual that will be on flap set up . It will explain how to mix in some down elevator with the flaps also your flap speed can be slowed down ,that often helps .
bikerbc is offline
Old 05-24-2014, 11:00 AM
rcworld2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok i found the page in the maual what do you think is a good percentage to start with the plane lifted up pretty strongly?
Old 05-24-2014, 02:00 PM
bikerbc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know , every plane is different and it depends on your flap settings but I would start at 10 % and see what happens . You should have two flap positions mid and landing so when the flaps are in the landing position you might want 15% . If it pitches down you will want less . That's where slowing your flap speed down helps . When it pitches up or down its not so violent and its much easier to control . You will need to play around with it till you get it where you want it .
bikerbc is offline
Old 05-24-2014, 04:19 PM
rcworld2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok I was able to set the flap mix for the landing but I haven't figured out how to set it when on mid.
also how do slow done speed
Old 05-24-2014, 05:09 PM
dumbthumbs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what radio are you using? I have one set up with a DX8, be happy to send it to you. The setup includes flaps,crow, and coupled flaps.Send me a PM if you want it
dumbthumbs is offline
Old 05-24-2014, 05:13 PM
rcworld2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
futaba 8fg super
Old 05-24-2014, 06:55 PM
bikerbc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine is a DX8 too and I am only familiar with how to set it up . The best I can tell you is there should be a section in your manual that covers flap set up . It should tell you how to set your speed and switch selection etc. . I think I have my flaps set to deploy in about 6 seconds . I am reluctant to offer too much advice because there can be a lot of difference in how these radios are programmed and it needs to be done right . One thing I can tell you for sure is don't ever throw your manual away . The Futaba's are supposto be fantastic radios and once you have learned how to programme it you are going to be very happy with it .
bikerbc is offline
Old 05-25-2014, 12:12 AM
flycatch
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Forget about flap/elevator mixing and use the servo slow function offered in the transmitter menu. Each servo assigned to a flap can be slowed and matched to the other. I'm using a JR 10X that is ten years old and it offers this option.
flycatch is offline
Old 05-25-2014, 02:34 AM
rcworld2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for all the help guys i will read over the flap section again and see if i can find out how to set the speed.
Old 05-27-2014, 07:21 AM
AMA 74894
Moderator
AMA 74894's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you can't set flap servo speed with a futaba 8FG super. (unless you use the throttle channel for flaps... something you'd ONLY want to do with an unpowered glider.)
you'll either need to use a programmable servo, put the flaps on a slider/ knob, or do without.
Futaba 8FG super -servo speed adjustment?
one other thought: although many airplanes will nose up considerably after having deployed the flaps, the tendency is made worse if you don't first slow the airplane down.
(in other words, dumping the flaps while at high speed WILL make the airplane 'baloon' )
AMA 74894 is offline
Old 05-28-2014, 02:59 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
These are the words of wisdom that I've been waiting to read.
If you are going too fast, when flaps are deployed, the airframe will balloon. Before trying anything else, I suggest that the OP slow his model down, and then deploy the flaps. My experience has been that this will cure the problem.
TomCrump is offline
Old 05-28-2014, 03:54 AM
bikerbc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rcworld2000 I apoligize for telling you that your transmitter might have the servo flap speed feature . I just assumed that because my DX8 had it they all probably did . .
bikerbc is offline
Old 05-29-2014, 07:30 PM
Charlie P.
Charlie P.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you can get a servo delay on the 8FG if you use the airbrake function. But slowing down the model first is a good tip.
I hit the CROW on my Hot Stik one time coming in for a low pass when I wanted dual rate. Did a DOWN 90 dive and I recovered just in time to shear off my landing gear! Yippee.
Charlie P. is offline
Old 06-06-2014, 02:31 PM
cat5752
cat5752's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know much about Futabas, but the Hangar 9 Ultra Stick .40 manual has a section on how to program the Futaba 8UA/S for flaps and crow. It is on page 75. Hope this helps.
cat5752 is offline
Contact Us Archive Advertising Cookie Policy
