ok now that im done with training i wanna convert my hobbico 60 to wing bolts
Reply
Old 06-03-2014, 08:00 AM
SrTelemaster150
SrTelemaster150's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've converted both of my trainers from rubber bands to bolts. The 1st was a Sr Telemaster, the other a USAircore Knight Hawk both of which were taildraggers.
It's not that difficult. While you have the wing under surgery, reduce the dihedral & wing incidence. I made up a new dihedral brace for the Sr Telemaster & converted to a 2-piece wing W/wing struts.
That Telemaster would do some crazy s*** W/an FA-150 on CDI in the nose.
Definately get rid of the tricycle gear!
For the steerable tail wheel just make a 2-piece elevator W/a wire "U" connector. Notch the elevators & run the rudder full width to the bottom. Then use a simple steerable tail wheel that connects to the rudder as in post #10.
SrTelemaster150 is offline
Old 06-03-2014, 02:41 PM
Calvinman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 Jester, the secret is to just not cartwheel. I do have to remove some material for my Ultra Sport wing bolts, but it is mostly just the threads and a tiny bit of the meat from the bolt.Calvi
Calvinman is offline
Old 06-03-2014, 06:00 PM
Avistarpilot
Avistarpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FWIW...I just cartwheeled mine today. Assuming it was a stall on take off but regardless the plane cartwheeled and only damage was to the firewall. The wings were cocked a bit in the saddle but no structural damage from what I can see. Been flying solo on and off for years and this is the first time this has happened. In this case rubber bands saved my wing.
Avistarpilot is offline
Old 06-03-2014, 09:42 PM
Calvinman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry to hear of your mishap Avistarpilot, glad it was not worse.having a wing that sits flat on top of the fuse so it can twist a bit does save on damage for sure. When the wing is "nestled" in the fuse and has no where to go even if the elastics/bolts allow it to move you end up with damage to the fuse and the wing. I hope the firewall is repairable with a little epoxy.Calvi
Reply
Display Modes
