Doing a weekend aerospace engie project, preferrably a single-spool turbojet, help?
Hi, I've done previous projects before, but nothing of this magnitude. I was looking at a Russian afterburner of attached to a P160SX (https://www.youtube.com/watch?v=pS6LCDmvM5U), and that got me hooked. Is it possible to replicate something like this from scratch? I can do fabrication with practically any tool, just need a rough spec to start calculations off of. Thanks!
Moderator
I've never heard of DIY plans for a turbine. There aren't many guys who can precision machine the parts and balance them well enough to turn 160,000 rpm without inducing any vibration. Then there is making a usable ECU for the start sequence and fuel metering, and so on.
Maybe building a pulse jet would satisfy this itch for a weekend project? They are fairly simple, but still nice and loud.
1 Post
On a weekend you could make and run a valveless pulse jet like this.
http://youtu.be/55JoyhDwggU Or maybe do something around an existing turbocharger and turn that into a self sustaining turbine
1 Post
Running turbine using a old turbocharger
http://youtu.be/xNs27JCrU8Y Even with access to CNC 5 axis milling and prepared cutting programs you a looking at weeks if not months to build a regular gas turbine. Attainable goals are best.
