Help with magnum xl 46
#51
Thank you, I already have my engine mount built. I still need a spinner before I can try to start my engine, as my spinner broke when I wrecked. What spinner would you suggest.
#53
iI you are going to use a spinner then yes a spinner nut like Jaka is posting however you are not making much sense first you say you are building a test stand then in the next post no. Sure would be nice not to waste our time responding to you so which is it.
As far as spinner or spinner nut are concerned you do not need either to run in a test stand or even to fly for that matter. Just remember to reverse the cup on your starter if you are using one.
John
John
#54
John
John
#55
Yes spinner nuts work fine with most starters but here we go agine, No you do not need a spinner or spinner nut when you are using a starter. Most starter 'Cups' are designed to reverse when not using a spinner. Step one: reverse the cup Step two: use two hands on the starter never a single hand Step three: carefully alighn the starter motors shaft parallel with the engines crankshaft before pulling the trigger. I have many airplanes without spinners or spinner nuts and yes I almost always use starters.
John
John
#60
Yep me too but i have done it with just a nut on the prop .like you said its not fun thay way tho. lol You want some real; fun ,put your leather glove on and start your G62 gas motor in your warbird and have it bite you a couple times ,still to this day brings a tear to my eye ! lmao joe
#61
My Feedback: (26)
TX
Do you hold your finger over the card, flip the prop by hand a few times, does the fuel come up to the carb? If not, might have a hole in the fuel line. Is the clunk line in the tank free to move around and not hitting the back of the tank? All of my Magnums have run well.
Buzz.
Buzz.
#62
MN
The rubber insert in the "cup" on your starter can be removed and reversed. The small hole then fits over the prop nut. Logic would also indicate that if you use a spinner, it is the nut that holds the back plate and the prop in place. A prop nut does the same thing does it not?? It is just a different shape.
#63
Actually starting an engine without a spinner/spinner nut Is quite easy if one truly bothers slow down and take the three steps I listed above. Very few people take the time to actually line up the shafts and if one actually stops just at the point before they pull the trigger and really look they would be shocked how far off they can be. That is what causes inserts to go off into orbit.
John
John
#64
Hey, Just wanted to let y'all know that my engine is now working. My glow plug was bad, my glow plug igniter battery was dead, and my carburetor seal was bad. But it does work now. Thank you for all your help.
