Planes pulls to right.
I am a total noob to RC aircraft.
My plane pulls to the right during takeoff then as soon as it’s airborne it does a half circle and crashes. Any idea why? It’s 4 channel trainer.
Thanks!
Thanks!
Sounds like the planes gear is off since it pulls right on ground. Since once airborne it continues to turn right the gear is off because the rudder is off. Everything needs centered.
are you correcting with opposite rudder?
you know I tried teaching myself with a glider. Failed miserably. It as another 20 years before I learned right get with an instructor
I have thought about an instructor. Unfortunately I live in the middle of no where lol. I do try correcting, that's how I get it in the air. It's a bixler 3 glider. I also have a avistar 40, but I am not really wanting to take it out until I get the bixler going.
Moderator
Since you are going it alone, your issue could be a plane that isn't set up correctly to start with. Find some tall grass. Toss your Bixler so it will glide and crash into the tall grass. That will protect it from damage. Watch what it does; you want to see a straight glide and smooth drop at the end. Try to do it when the wind is calm or at least blowing in a direction that lets you launch straight into it. Once you know your plane will fly straight, you can work on making it handle straight on the ground. And once it will do that, you'll know that it should takeoff straight. Flight trimming is a whole 'nother set of skills we can help you with too. For your first few flights, takeoff close to that area of tall grass I mentioned before. You can cut the throttle and crash the plane into it to save it from damage. Once you have a little more control, try to fly the plane level into the grass. Then work on touching the wheels to the ground just before getting to the grass. Once you can do that, you'll be able to land normally.
All that said, even just one session with an instructor will save you hours of frustration and significant money. Consider finding someone to help you even if it means driving for an hour or two to meet them. It's worth it.
Check for warps, sounds like the wing is warped since it pulls to the right whether on the ground (taxi) and in the air. Carefully examine for wing or stab warps by looking at the plane from the rear as it is easier to see a wing warp from the aft view.
The fourm won't let me upload video yet.
I did the glide test, it flew straight into a smooth drop.
the seam under the plane had come apart allowing the wheel to travel a lot. I taped it up and now it at least taxis straight. The rest of it may be my crappy skills
I went to the ama website. I found a club/trainer about 40minutes away and sent him an email. Thanks for that tip.
Is there any trainer planes you all recommend?
IL
If your young and quick, your avistar and powered 4 channel glider should be just fine.
I would wait until you get a conversation going with your instructor and follow their advise about any futher purchases. Except for the sim, a sim is never a bad idea.
Moderator
You should fix the bottom of the plane better than that. Some epoxy should be able to repair the mount. Just think about how much strain that landing gear mount is going to be under in a hard landing. Then think about how much damage it will do when that gear leg rips out and leaves the plane skidding and tumbling across the ground. Take your time and get it done right.
If its a pusher prop with small propeller behind pushing the plane, then check if the plane tail boom doesn't twist or wag around especially the ones made from foam.
Moderator
Geez guys, we are talking to a brand new pilot who's flying a factory built plane. I haven't seen an ARF yet that had a wing too twisted to fly. Imperfect sure, but not so much to make it impossible to take off. The most likely explanation is pilot error, second most likely is the plane is out of trim. For that matter, it could be that he was taking off in a cross wind and didn't think about it before posting. As long as the plane isn't damage though, it's likely not the problem.
A common beginner mistake is to give full power on takeoff on a type of plane that does not need it. I like the glide test mentioned above. That's how I started with my own plane (TF Schoolmaster, Cox 049, Ace throttle, RT control) years ago, and I taught myself with it easily.
Once the plane can glide well, then adding a little power simply extends the glide; bump it up a little and it will climb.
The throttle is your bail out. Picture the flight in your mind and train yourself to cut the throttle if things start going wrong. Turning becomes the next problem, since it reverses coming toward you. Picture it in your mind, you can also turn the tx so it is oriented the same way to the plane. Cut the throttle when you get in trouble. Flight times will increase. Good luck!
Jim
Jim
One more thing. An easy way to check for warps is to attach a straight stick to each wing toward the tips and parallel to the fuselage. A rubber band will hold it. Then put the plane down and stand back looking at it from the side. If the sticks are at different angles you have a warp. I check my models this way before a maiden flight.
But if the plane glided straight with the rudder straight, then you don't.
Jim
Jim
