design FW 190 A8
1 Post
I would start here free plans
A high street print shop can usually manage a one piece or two piece copy for you. They can scale it too if required.
NB You can get support on this sort of build in the scratch build forum further down in the forum list.
I am assuming that you have a set of wings and a broken fuz but in case you are starting from a blank board consider building the extended wing version the FW TA 152. This is a MUCH nicer aircraft to fly and is not as sensitive to weight and less likely to tipstall.
Keep it light !
Keep it light !
