Great Planes Big Stik 40 - Tail Heavy or Thrust Angle
#51
You don’t use the elevator to tighten the turn.
The problem here, as I see it, is that you do not understand the forces that come into play during a turn; vertical component, horizontal component and weight. Also speed and drag come into play.
Basically in steady level flight the forces are balanced. When you bank an airplane you need more vertical component to maintain level flight as the weight factor increases. So you add up elevator to increase lift to maintain level flight. The greater the bank angle the more vertical component you need.
In a 45* banked turn your 5 pound airplane may weigh 7 pounds. You have to use your controls to balance this out. Rate of turn, radius of a turn, is a combination of bank angle and speed.
A little study of the Theory of Flight may give a better understanding than what I have written here.
So just to clarify, I started flying fixed wing in 1985. I flew regularly until about 2008, at which point I gave the hobby up because of work and home commitments. I also intended to return ‘next year’ but the years just flew by and I have only just returned.
In my time I have flown loads of different planes (trainers, high/mid/low wing sports, biplanes, funfly, scale), I have always used elevator in banked turns to keep the nose up and to perform a tighter turn and never ever experienced the sort of thing I saw yesterday.
And just so you don't put it back to my return, about two months ago I had to opportunity to try out various electric aircraft, including a high wing trainer, a Wot 4 and an Acro Wot - I had no problem at all with those.
This violent pitching up is something I have never seen. Just to be clear when I am in forward level flight I have to use full elevator to pitch up anything like what I am getting in a banked turn when I lightly touch the elevator.
Cheers,
Nigel
#52
Hi!
Sounds as if you have way to much elevator travel! This could be due to too forward Cof G! How much elevator travel do you have (in mm at the trailing edge). I assume 10mm would be enough if the Cof G is "correct"
#53
Elevator is as per instructions 16mm at low rate. Also have 30% expo (-30 as it is Futaba) so it really won’t be moving that much in the turns.
And as I said, the natural first thought would be too much elevator but on level flight it seems really docile - to get the same amount of pitching up I have to yank back on the stick.
Will continue to experiment but so far this plane isn’t behaving like anything I have had before.
Cheers,
Nigel
#54
I would take out all or most of the expo. When I have used expo, 30% or more, I tend to way over control. A little, little more, little more, WOW, too much!! Whenever I do use expo, it's 5 to 15% If you are using recommended throws, you don't need much expo. If you are using some wild throws (3D), then you will need some more expo. Your last flight sounds just like one of mine with too much expo, thinking it would calm things down a bit. It ended up with too much over controlling and a hard time bringing the plane home.
Skyhawk
Skyhawk
#55
in a banked turn, the tail is affected by gravity and centrifugal force and the deflection of airstream over the elevator, but no one single for is prevalent. in comparison, the effort need to raise or lower the tail in level flight is greater because gravity is the prevalent force at work . using elevator in slightly banked turns acts on two forces that neither one is prevalent in the plane of displacement so the displacement of the tail becomes easier in the bank, resulting in what appears as a flair. adding some rudder to counter adverse yaw in a bank, compensates for the lack of gravity's pull because the plane of displacement is neither fully vertical or horizontal.
#56
But it's just a Big Stick (Ugly Stick)! This ain't rocket science. I have no clue why Nigel is having these problems.
As I've said before, this plane should be a no-brainer.
P.S. Nigel. take out all of the expo. You should not need it.
#57
But I will take out the expo for the next flights.
Cheers,
Nigel
#59
There still may be a bit of a CG mismatch, but at least subsequent flights have shown it to be not wildly off. Next time you fly, try this:
Rusty pilot test, but not too accurate:
Trim for full power level flight. From straight and level, full power, bank to 45 degrees. Do NOT touch the elevator. Does it tend to descend - a little or a lot? Or does it stay level, or even climb a bit? If the first - it may be either right on, or nose heavy if it descends quickly. If level or climb - tail heavy. Better to err a bit on having a little descent, than to stay level - which may become tail heavy as you burn off fuel.
The better, but more skilled pilot test:
Trim for full power level flight. Fly straight and level, full power. Pull up to a 45 deg. climb. Neutralize elevator. Roll inverted. Do not touch elevator. If plane does a nice, long gentle arc down, CG is about right. 3D guys look for a continued straight line, but this isn't a 3D plane. If it climbs when inverted, it is tail heavy.
While a Stick isn't a full bore pattern or 3D airplane, it IS still a pretty good aerobatic plane. So I wonder as to why it is going into a nice, wide banked turn on just ailerons. It should continue on mostly straight, or with a gigantically wide turn. Make sure that is actually happening and that you aren't subconsciously feeding in a slight bit of elevator to compensate for any loss of altitude it might have (which would also produce a turn)
Early on you mentioned thrust. Do this:
Trim for full power level flight. Fly full power, straight and level. As it approaches you, chop the power to idle. Do NOT apply elevator. Watch what it does in the first few seconds after chopping power, before it slows a lot. If it starts to climb, even a bit, you need upthrust. If it starts to dive, you need downthrust. You want to see it maintain level while it still has speed, gradually transitioning to a shallow descent. You may have too much downthrust, causing you to carry some up elevator to compensate - which could also exacerbate the turn issues you are seeing. But get your CG and thrust sorted out, before chasing the turn issue.
Note: If you are tail heavy, it can sometimes look like a thrust issue - the plane has some down elevator (makes more lift) to help carry the weight on the tail at full throttle. When you cut power and loose airspeed, the tail can't provide as much lift and the tail drops. Causing the nose to pitch up - making it look like you need upthrust. So verify the CG by doing the above tests several times, before messing with your thrust lines.
The point of both the above is to eliminate, as much as we can, elevator trim that is needed for other issues, that may be contributing to your turn concerns.
And while you have seemed to indicate that the ballooning is not really present...check your pushrod to the elevator for flex! When you try to move the elevator by hand, you should not be able to move it unless the servo arm itself moves. If your pushrod is bending under load, it can lead to all sorts of poor handling situations.
#60
Moderator
I'm just taking a shot in the dark at this point here, but could it be that you have some significant adverse yaw and so not banking the wings as much as you'd expect, resulting in the up pitch when you expected it to turn? If you have the ailerons set up with equal throws up and down, you definitely have some adverse yaw.
#61
I'm taking the expo off. If I think back I have never flown with it before except when I started to learn on helicopters. I'm a 'thumbs on top of sticks' person, an my heli tutor tried to reprogram me to use the pinch method but it was just too alien. So he put in expo to soften it around the centre. So probably still need it for helis but not fixed wing.
As for ailerons - yes they are equal. I've never felt the need to use differential ailerons before, but worth a try, I will put it in before the next flight.
Cheers,
Nigel
#62
Did you get a chance to do any of the tests I'd mentioned in post 13 and 43? Those are just a few of the attitudes and exercises that can be done that might/can offer insight.
As mentioned, it's just a Stik. We've all had a few of them at one time or another. I have one right now. It's one of the best flying sport planes I have.
Nigel, your Stik is very much a mystery. Good luck with it, I hope you get it figured out.
#63
First session I was sure the CG was correct, but flying made me think it was tail heavy.
Second session, I checked the CG and it seemed spot on but because actual flying experience was suggesting otherwise I moved the CG forward. When it flew I could tell it was definitely nose heavy, no doubt of that. Assumed there was no point in trying any tests when it was clear it was out of balance.
So next time I will put the CG back and try your tests.
I’m limited to weekends because of work, and weekends also get taken up with other things - this coming weekend I’m away visiting family.
Cheers,
Nigel
#64
Hi!
As the others have said : Its just a ARF Stick and as such should fly just perfect right out of the box if the Cof G is at 25-30% cord.
Change elevator servo! And then set up the linkage so it is stiff.
#65
Moderator
I'd leave the expo too. There's a good reason why it's in every computerized radio on the market- because nearly every plane you'll ever fly flies better with it. Most planes get a linear feel to the controls somewhere around 30% expo. Sure, you can get that almost/too much break over with too much expo, but the amounts you were using aren't going to do that.
#67
I've rarely, if ever flown with expo. I don't like the increased sensitivity at as you move the sticks.I suppose it's good for 3-D type planes with huge control surfaces and massive throws, but that ain't what we're talking about here. Again, it's just a Stick!
#69
EXPO - I will remove this - it is a hangover from my helicopter flying - I have never used it for fixed wing before. I'm a dyed in the wool, 'thumbs on top of sticks' flyer which is not the best for heli flying. I did try converting to the pinch method but it was far to alien to me. The problem with heli flying is that you need constant tiny precise movements around centre which is difficult to achieve with thumbs on top. So the remedy is add expo which reduces the sensitivity for at the low end.
AILERONS - at present, it is set up as per instructions, equal movement up and down. Someone has suggested turning on differential ailerons and I will try that.
But to be honest, whilst I'm happy to try anything, I'm not holding my breath. After all this is just a STICK and it should just fly - that has been my experience with sports planes up to now. Fiddling with expo, differential ailerons, tiny changes in CG might finesse the performance but they are going to be the difference between flying badly and flying nicely.
Cheers,
Nigel
#71
Mine doesn’t fly like that. I have the control surface throws on low at the monent so its loops are big and it won’t roll like that, big barrel rolls.
But when you watch this one turn at the ends of the circuit it is quite tight and flat. With mine it will eiether do really wide turns if I use aileron alone or it will pitch up quite aggressively as soon as I touch the elevator. The odd part is that if I use the elevator to loop in level flight it is pretty docile resulting in wide loops even on full stick.
It is on low rates so the wide loops and barrel rolls are not surprising but the pitching in turns is.
Cheers,
Nigel
#72
Okay, I watched the video, such as it is. I had to move it to my You Tube channel to see it full-screen.
It seems the pilot in the video lacks certain skills. But that's a different topic.
A barrel roll requires some up elevator along with aileron input, as well as rudder, depending on the design. I'm afraid without flying the plane myself, I can offer no further advice in regards to your problem, except to again suggest you let another pilot fly your plane to get a fresh perspective. I know you don't want to do that. But, maybe just take it up yourself and hand him the transmitter?
Other than that, I don't know what else to tell you. Good luck.
Regards,
Richard
Regards,
Richard
#73
Yes I’ve watched a few like this one
https://m.youtube.com/watch?v=WIBUrfwK11Q
Cheers,
Nigel
As a couple of us have noted:
1. Make sure all flight controls are solid - unable to flex under load, servos are holding against loads, no slop in linkages. That is the most common cause of the issues you are seeing.
2. Finalize your CG and engine thrust by flight testing as noted previously. This removes them from consideration.
A Stick, or similar airplane, should not do a wide turn on ailerons alone. Period. With a symmetrical airfoil, low/no dihedral, and wing close to the centerline, it should only roll. Maybe not perfectly axial, but it should not do a turn. Verify this turn is really happening, and you are not unconsciously inducing the turn by slightly pulling back on the elevator. Bank to 45 deg or more, and let go of the stick completely, and just watch.
If it really is, then likely you are carrying too much "up" elevator when level. As you bank, the wing is no longer fighting gravity, and the excess lift goes into making the plane turn. (And then you add in even more by pulling back on the stick, and it balloons....) Improper engine thrust would be the first cause of needing to carry up elevator. And CG can impact engine thrust. Hence why getting those two set right first are critical.
Only after that should you then delve deeper into wing/tail incidence, etc.
Expo is personal preference. But if you are comfortable enough not to use it, do so - one less thing to factor into the complexities of trying to sort everything out.
#74
as to pushrod flex,...I use carbon arrow shafts with typical pushrod wire ends epoxied into them. they weigh nothing and are about as rigid a pushrod material you can find. I use a marine epoxy designed for fixing gelcoat on boats. it is relatively thick and very adheasive to both the arrow shaft and the steel pushrod material. I usually glue about 2 inches of pushrod into the shaft by filling the end of the arrow shaft and leave enough steel shaft to exit the fuselage with only the wire. I also put a small bend in the steel shaft inside the arrow shaft to ensure it won't slide out, should the epoxy fail, but never had a problem. I've tried all sorts of methods/materials and I don't think you can make a lighter, stiffer linkage than this for the money.
#75
This is not a question but just food for thought. Very low stick time can cause extremely wild, erratic, jerky, panic stricken short flights. Just sayin... no response necessary
