New to rc HELP
New to rc HELP
I am brand new to the rc community, and I want to get into bulsa kit builds. I decided to go with the dandy sport from mountain rc for my first build. From the threads I have found people seemed to have gone with the emax 2805 1300kv. However I can't find this motor anywhere online. I think the next closest thing might be the Emax GT2215/09 Motor. This is the info on it from heads up rc: Emax GT2215/09 is a 2.4 ounce, 400/450 class, 1180KV, 280 watt outrunner brushless motor. It's a good choice for sport planes weighing 18 to 35 ounces, and 3D models weighing 15 to 25 ounces. (the dandy completely finished weighs 13-14) a picture of the propeller test data is included below. I was thinking that the best option for it would be:
battery: 2-Cell 7.4v
prop: APC 11 x 5.5E
I still don't know exactly what battery, or esc. I'm open to a different motor as well so If anyone has any better options for my build I'm willing to give it a shot.
prop: APC 11 x 5.5E
Moderator
From the description I found, the recommended motor is a tick better than a park 300, whereas the motor you are considering is equivalent to a park 450. That's adding an ounce to the nose of the plane, which would be noticeable. Plenty of manufacturers make a 1300kv (or close) motor in the park 300 size and power range.
Thanks jester,
I am now thinking of the Suppo 2208/17 1100kv Brushless Motor.
20a esc
3s 11.1 Lipo. (what mah should I get to maximize flight time without sacrificing too much weight?)
20a esc
Moderator
That should work better.
I've generally found that it's better to err on the light side with batteries. A plane that size probably won't need more than an 800mah and may fly better with something smaller. The good news is that those batteries are cheap, so buy a couple. Again, recommendations from people who have built this plane can be very helpful.
On the topic of battery size- more capacity doesn't always equal more flight time. With more weight, you'll need more power to stay flying, which uses up your capacity faster. There is a happy place where that balances out, but IMO it shouldn't be your biggest concern. Build the best flying plane possible and enjoy it. If you only get 5 minutes of flying per charge, that's ok. Buy multiple batteries and a good charger.
