Mystery Plane Identification and Help
I picked this one up along with the AirCore I made another thread about. It doesn't have an engine or radio. Any clue what this one is? Also, what is going on with the wing lacking the movable aileron leading edges? How do I fix this?
Thank you. What engine size would you recommend for this plane. I really like Super Tigres. Can you still purchase new ones?
My Feedback: (29)
Super Tiger is long gone. Lots of them for sale on EBay though. Power wise the 34 would be ideal IMO but may be a bit on the light side for CG. A .40 would balance better but a bit more power then needed. Not usually an issue as you can always throttle back. An OS FP .40 would also be a good choice as would be a K&B .40 or a Webra .40 blackhead ( non speed ).
Hi Allmodes.
This is not related to the topic - but the plane does look like a Kadet Sr.
I wanted to ask how you uploaded your photos to be smaller in the post, then they enlarge when you click on them?
I try to upload and they end up in my text as a MONSTER photo..
Thanks...
Thanks...
Hi Allmodes.
Thanks...
Thanks...
https://postimages.org/
I ended up buying this Super Tigre that is claimed to have only 2hrs of run time. Two questions:
1) Is there supposed to be a gasket between the exhaust port and muffler?
2) There are two washers attached to the bottom of the engine in the pic. Where are these supposed to go?
This engine will serve you well with the Senior. By the way suggest you do not give into temptation to try and add ailerons just because this one is a three control variation. All the kit built versions (78" ws) were without ailerons and in no real way required them.
This Senior will become a treasured keeper for you unlike you other trainer project the Aircore.
John
John
10-4 on the ailerons. I would not want to start making a mess of the wing anyways. Two questions:
1) What size propeller would you recommend? I have the following:
a) black plastic 10x6
b) black plastic 11x7.5
c) wooden 10x7
d) wooden 11x6
2) Is Wildcat Premium Plus fuel okay for this Super Tigre and the OS FP Max engine in the Aircore? I have been running this fuel in my older Super Tigre and just want to keep it all the same. The Plus has a bit more oil in it.
c) wooden 10x7
d) wooden 11x6
1 Post
11 x 4 prop. STs mostly like to rev.
Grey Graupner is my prop of choice for beginners as it less likely to break on a prop strike while landing. Black Master is second choice.
The throttle/rudder will stay on the left stick and the elevator will be on the right. That's a pretty plane. I don`t have one, but I helped a friend get started flying who had one and they are in my opinion an easy to fly, very graceful bird. Like John Buckner said a treasured keeper. Also I think you can`t go wrong with the SuperTigre engines. I bought some old airplane stuff in a second hand shop which included a Supretigre 61. After cleaning off the old gunk, it started up and with some minor mixture adjustments, ran like a champ. It now powers my Carl Golberg 60 and hasn't failed me yet.
My Feedback: (29)
On a 3 channel airplane the rudder should always go on the right side. I actually prefer to do a mix so that rudder will be on both sides, after flying for 43 years I have issues ground steering with my right hand. Having rudder on both makes it easy for me to ground steer with my left hand and fly with my right. Most guys would be similarly accustomed. CG should be 1/3 of the wing cord. No need to go any farther forward then that, it will only make the airplane more difficult to fly and land faster.
Now that is an interesting thought. I've never heard of anyone doing that before. It does, however, make a lot of sense.
Hmmm, I guess being used to flying the regular 4 channel mode it would be easier since you`re just minus the ailerons on the right side. I have a 2 channel Cox/Sanwa which has the elevator on the left and rudder on the right. I`m planning to get a spectrum 2 channel receiver so I can add it to my radio and be able to configure it the way I`m used to which would be to have rudder on the left and elevator on the right.
With regard to the rudder stick, the old school will say that you need to learn to use left thumb. The bank and yank crowd will say go with the right thumb. I've done both but prefer to keep the rudder on my left simply because that's where my rudder reflexes are. One thing about it, those old three channel trainers are sufficiently stable that as long as you can maintain enough presence of mind to remember which hand has the throttle you can switch channels on a 4 channel receiver easily enough. If you are comfortable enough with flying to test out the changes that you make to you airplane then try it both ways. If it makes you nervous, remember that even experienced pilots are okay with having a trusted spotter who will remind them of what to do.
Was a short day since I lost one of the rear wheels in flight. Saw something falling down from the plane and thought it was my muffler at first. Surprising I landed very smoothly with two wheels, LOL. Got the wheel situation sorted but now I need exhaust gaskets for the Super Tigre as he's leaking goo all over the place. Anyone know if these will work? It says they are for the G-34 engine and I have the .40. Perhaps somebody has some that you want to sell? Might as well ask if anybody has an intake gasket for this engine.
https://www.ebay.com/itm/1-PZ-SUPER-...EAAOSwuUlb8oUJ
You guys were not kidding when you said how gracefully this plane flies. Very nice to say the least.
