AR620 Receiver compatibility
Reply
Old 10-19-2019, 08:14 PM
Real2You
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default AR620 Receiver compatibility
Hello all, Hope you can help me. I'm in the middle of a Kadet Mark 2 build. I have a Specktrum DX7, AR620 receiver and Futaba S3010 servos. I had no idea the futaba servos don't fit in the AR620. My question is....can I cut the futaba servo to fit the AR620? Everything looks the same but its got a tab that sticks out a little and therefore it won't fit in the receiver. Or...what receiver can I buy that will take a futaba servo and work with a Dx7(and a DX8 Version 2). I thought I would ask here first before calling the hobby store on Monday.
Real2You is offline
Old 10-19-2019, 08:29 PM
Real2You
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After more searching I found a Thread in here that says you can cut off that tab on the servo so it will work. In the future I need to find a different receiver because I have a lot of futaba servos.
Real2You is offline
Old 10-20-2019, 05:12 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you're flying a DX radio you're gong to have to shave the tabs. Almost everyone is using regular servo connectors these days and you won't find a spektrum rx that will accommodate those tabs
BarracudaHockey is offline
Old 10-20-2019, 05:26 AM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's nothing to stress about. Those tabs keep you from plugging the servos in backwards on a Futaba receiver. It was a good idea that other manufacturers never picked up on. There's nothing wrong with cutting them off.
jester_s1 is offline
Old 10-20-2019, 06:30 AM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes cutting the tabs off Futaba plugs is a modern ritual that every modeler who flies a wide variety of equipment has to deal with and as Jester noted "nothing to stress about". Actually this is a cakewalk compared with what we once had to deal with considering ; JR plugs, Airtronics Old, Airtronics New, Hitec S, Futaba G and Futaba F, #3 pin positive, center pin positive. The list goes on.
Whats important for you to remember is Yes Futaba puts the tab there to prevent plugging the servo in backward 'However' This will not harm the receiver nor will it harm the servo bottom line! It simply will not work. If you just cut the tabs and installed your servos only to discover say a rudder is not working just check the servo plug is not backwards, Just turn it around and Boom Done. No damage and no foul.
Now the simple way to avoid this and always plug your servos correctly without the need for the tab is to just look at the black wire side of the plug and line up this black wire of all the servos to the outside edge of the rx case or the bottom edge of the case depending if the rx is a top plugging type or an end plugging type.
OK to cut the tabs I prefer a #11 blade in a series of small cut not trying to do the entire tab at once. If you do you run the chance of ruining the plug housing itself. After cutting the tab cutting or sanding a slight bevel on the two bsckside corners of the plug will improve the plugging action.
John
JohnBuckner is offline
Old 10-20-2019, 12:45 PM
Real2You
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys! A cutting I will do...
Real2You is offline
