Super Sportster
KY
Super Sportster
i was looking on tower for a second plane what do you think about a .40 sized arf super sportster with a super tigre 51 and 6exa radio?
RE: Super Sportster
Likewise, I dont know anything about the plane.. but the engine and radio should do you well. I have had a 6EXA for several months and it has been a great radio.
RE: Super Sportster
I had a 40 size Super Sportster as my second plane and loved it. That was eight years ago and I eventually lost it to over confidence.
I liked it so much that I bought a new one last year and flew it a couple times every week. It's my favorite plane at the moment, and I fly it with a Thunder Tiger 54 four stroke.
I'll warn you that the plane is very fast on an OS 46 FX (another guy at our club has one, and I flew his trim flight for him), so the Super Tiger 51 might be a bit much. Most Super Tiger engines are also quite heavy, so you might want to re-think the engine. (Try a TT 46 PRO, it's less money than an OS 46FX (AX now), or the plane would fly fine on an OS 46 LA. My first Sportster flew well on an OS 40FP.
The Futaba 6EXA is a good radio (I have the 6XAS which has a couple more features). I think you'll like the radio.
One bit of advice. If you fly off a grass runway, do NOT use the wheel pants. I had them on my first Sportster and the pants kicked right up through the wing on a couple of occasions, I took them off.
Good Luck,
Dennis-
Good Luck,
Dennis-
My Feedback: (15)
OK
RE: Super Sportster
I love the Super Sportster and it can really move. I have a O.S. 46SF in mine and the landings were a bit hot. I tamed it by going with a shallow pitched prop. Currently running a 11x5 and will try a 12x4 to see how it does. Great vertical and tracks arrow straight. Move the CG back a bit and it will spin nicely. Not a flat spin, but nice and recoverable. You will like it.
Jesse
Jesse
GA
RE: Super Sportster
ICE_MAN,
I have both the SS (kit) and the 6EXA. Great combo! The plane is powered with a ST 45 and is !QUOT!monster fast!QUOT!. It'll land hot, or as docile as you want, provided you start throttling back early. In fairness, I'm swinging a 10x7, so a larger dia prop with less pitch would slower her down quicker, but that would take some of the !QUOT!Monster!QUOT! out of fast.
My Feedback: (8)
RE: Super Sportster
The Super Sportser is a great plane with not a bad bone in its' body. If you slow it down, it will just mush until it falls out of the sky.. no snap. Fast is a relative term and I never really placed this plane in the "fast" category. Yep, it will be faster than a trainer... but nothing to keep up w/a a REALLY fast plane. The plane builds easily but requres a bit of sanding skill to make it look like the box. The ARF looks ok.. but who built it? I just prefer to know exactly how the airframe I'm flying was put together. I've seen too many covering schemes that looked good and then find out that the glue joints weren't really doing a lot. Have fun.. nice plane.. simple to set up, and no bad faults. A very good 2nd plane that can either have tricycle or tail dragger set ups.
Deadstik.. [8D]
Deadstik.. [8D]
WV
RE: Super Sportster
I have a Super Sportster also with an OS .46 FX. Unlimited vertical. I'm also running an 11x5 prop and it seems to be a good combo....I agree with the Super Tiger being too heavy......I already had to add 1/4 oz. to the tail of mine to balance with the OS.
Once you get very comfortable with the plane, crank up the throws as far as you can....it turns into a REALLY fun plane!
Oh, and like DBCherry said, leave off the wheelpants for grass fields!
VA
RE: Super Sportster
I love the super sportster. I have had the 40 size kit for about three and a half years now with an os 40 fx. Flies great. Lands very easily, and gets going fast if you want it to -- rough guess about 75 mph based on prop pitch and rpms. Mine does not fly inverted very well, but I haven't tried to figure out why that is, and I just deal with it.
I crashed mine earlier this year following some radio interference. I nosed straight while on final approach. The balsa nose section was damaged, but nothing else was. So I cut off the balsa nose and now the plane looks like a cross between a sportster and an ultra stick with the engine hanging out there in the breeze. It's ugly, but it still flies great.
I almost went for the 60 size this winter, but I decided to go with the 60 size gp extra 300 this year.
RE: Super Sportster
ORIGINAL: ICE_MAN
Patrick
My Feedback: (7)
RE: Super Sportster
Glowplug,
Thanks. I bought the plane below for the 50, but I couldn't get it to work due to the shape of the cowl at the bottom. I would of needed an exhaust extension of at least 1", and I didn't want to alter this, as it's new. (ended up using a ST 61, and gave it the maiden last Sunday) It's a Kyosho Sensation. SOOOOOOO, still looking for a plane, and the Sportser looks like a good candidate!
Gary
Gary
KY
RE: Super Sportster
I will get this one then. first one will no really bad reviews. i already have the radio and engine in my trainer so thats what ill be using. THANKS!!!
RE: Super Sportster
I have the SS with an Irvine 46 MkIII. Its so fast I only use half throttle for most of the time.
I use a 10x7 prop but like the suggestion of an 11x5 or 12 x 4.
I also have the Futaba 6exa it is an excellent tx for the money and I have no problems with it.
I agree that if you are running off grass to leave the spats off. Mine went through the wing on the very first landing.
Personally I didn't like the ca hinges and replaced them with pin type ones. The ailerons had to be replaced by my LHS as they were banana shaped when I unpacked the parts. But it was well worth the trouble and it flies extremely well even at low speeds. I have no trouble with any of the standard aerobatic maneovres and mine flies well inverted.
A recommended plane.
WV
RE: Super Sportster
Patrick,
Before you go out and buy that JR...you might want to take a look at this.......
http://www2.towerhobbies.com/cgi-bin...I=LXGAE9**&P=G
This just might be THE new standard in the $250 price range.......definitely NOT last generation!
My Feedback: (197)
MN
RE: Super Sportster
ICE MAN,
Your super sportster will grow on you. I flew one all year and still enjoy taking it out. I used it as my second plane after steping up from a Kadet LT 40. Everyone says that this plane will land slow, but be careful not to land too slow, or you will stall the plane. Mine broke in half when it stalled landing on a windy day. It was a very easy repair due to the balsa construction of the plane. I fly with an MDS 48 on mine also, and it has plenty of power and vertical. Enjoy.
RE: Super Sportster
Patrick,
Don't know why you'd call the Futaba 6EXA "last generation". The 6 EXA has only been on the market for a few months. As you said, you don't even have a plane yet, so what makes you an expert on radios?
waagbuck,
Definitely something wrong with your Sportster if it doesn't fly well inverted. Mine flys just about as well inverted as upright, just requires a 'little' down to maintain. (I could probably feed in three or four clicks of down trim and fly it inverted.) What seems to be the problem with your's? Needs too much down elevator? Tries to roll out? I'd check the CG.
Hintydude,
I'd suggest a smaller pitch prop. I use a 54 four stroke and a 12 X 5 prop, and I can easily make loops that are 50 or 60 feet in diameter from level flight. You'll have less speed but more vertical with an 11 X 5, but it sounds like you don't use the speed so...
Dennis-
waagbuck,
Hintydude,
Dennis-
VA
RE: Super Sportster
I have never tried to figure out the problem. Basically when I fly inverted I need a whole bunch of down elevator to keep it level. It will do it, just not nearly as easily as some of my other planes. Could this be a CG thing?
RE: Super Sportster
CG would be the first place to look with that kind of issue, assuming the plane flys ok elsewhere. When landing, do you run out of elevator? How does the plane snap and spin?
If it's not CG, then it could be a combination of aileron alignment and elevator trim, but CG is the most likely.
RE: Super Sportster
ORIGINAL: glowplug
Patrick,
Patrick,
To DBCherry, I came right out and said I'm not an expert so that you could take my response with a grain of salt. I wish more people would be so honest as to be able to make a statement and admit that it may not be the ultimate last word instead of spouting off as if they were an expert when they really aren't. Frankly, I have spent some time looking at the Futaba6 and the JR6102 and from my limited knowledge (and words from actual 'experts') the JR looks better. That's all I was trying to say. I was just trying to help out a guy who's in a similar situation as I am (looking at new radios - although it appears now that he already has the 6EXA from his trainer and isn't looking for a new radio, as it first appeared) by sharing what I have found out so far, but also letting him know that I'm not an expert - just trying to make sure he knew what else was out there. It appears now that the 6EXA actually is the 'last' generation, as the new 7CAF is now coming out. Maybe 'last generation' was a bit too strong, but you'll have to forgive me for not being able to think of a better way to phrase it at the moment. I'm not trying to say it's not a good radio, just that there are newer radios out there with more features in the JR6102 and more channels in the F7CAF for the same money (I don't know exactly how the features of the 7CAF stack up to the JR yet).
WV
RE: Super Sportster
Patrick,
One other thing I've learned about computer radios.....in addition to looking at the features, make sure you ask around about ease of programming from people that have the radios that you're interested in. I've heard that the 7C programs like the 9C that I have, and I can tell you, it's a very easy radio to use. Sometimes features on paper won't help you if it's too difficult to program them correctly. Good luck with your radio shopping!
RE: Super Sportster
The wing has a small amount of dihedral. When it's inverted, it becomes anhedral and is hard to hold steady. Hangs from the prop good though. I already said mine is powered with an MDS .48 and wanted to add that I use 11x5 wooden props.
RE: Super Sportster
ORIGINAL: glowplug
Patrick,
Patrick,
That actually brings me to another question I've been meaning to ask. It's a bit off-topic, so maybe I shouldn't thread-jack, but... I guess I'll just say sorry if I do. How long can I hold out before buying my radio/servos? Will it really hold up the putting together of my plane (Avistar ARF), or is it something that's easy to install when the rest of the plane is finished or near finished?
Patrick
