GP SUPER SPORTSTER .60 ADVICE
AZ
Well my gp super sportster came in the mail yesterday unpacked it and it is very cool. I would like some opinions i'm thinking about putting an o.s. .91 in it for a power plant and also would you recommend putting the servos in the wings. If someone has a picture of how the changed where the landing gear mounts instead of in the wing i would love to see it i did a search and most people recommend to move the landing gear from the wings.
thank you very much
Rich
thank you very much
Rich
RE: GP SUPER SPORTSTER .60 ADVICE
The Super Sportster is a real nice plane, no matter what the size. The OS 91 will be plenty of power for the 60 size.
I'd set up as much control throw as you can on the ailerons, the recommended throws are very conservative.
To move the landing gear,; get an aluminum "dural" type gear (solid aluminum, not wire gear), then mount a good piece of 1/8th to 1/4 inch aircraft plywood in the bottom of the fuse just forward of the wing bay. If possible, add triangle stock on top of the ply at the fuselage sides to help reinforce it.
I used blind nuts mounted in the plywood, and bolted the landing gear on that way. (It's not hard to do.) I used 3 nylon bolts (4/40's) to mount my gear, but mine's a 40 size. I'm guessing that 4 would work for you. The nylon bolts will shear off in a bad landing and prevent the bottom of the fuse from ripping out.
Good luck, and have fun!
Dennis-
Dennis-
IA
I mounted landing gear on mine just as DBCherry suggests. The O.S. 91 should provide plenty of power. I have a ST .75 on mine, and it has plenty of power.
I hope we are talking a 91 4 stroke. A 91 2 stroke would be serious overkill. The 91 4 stroker would be fine. A good 61 2 stroker would be fine also. Good luck with your plane.
Mark Shuman
Mark Shuman
AZ
what kind of performance would a o.s. 61 2 stroke have in this plane and thank you for the responses i can always find good advice here
thank you very much Rich
IA
I believe the os .61 would provide plenty of power depending on what your looking for. My SS60 with a ST.75 and an apc 13x6 prop has nearly unlimited verticle. It's not 3D, but I can take off and rotate to about 75 degrees and rocket skywards. My personal opinion is that my ST .75 is overkill on this plane.
I had the webra speed .61 in mine with a pipe. I have another kit and will put a .91 two stroke in it. I have retracts so it is a little heavier. The 61 was pleanty of power. The 91 will be even more fun. It will hover on a good .61 if you keep it light.
