3 blade prop HELP!!!!!!!
i was running a 2 blade prop on my os91 FS it was flying nice and level, than i change it to a3 blade12x8 and my plane stared climbing out, should i change the prop to a 13x8 3 blade,let me know.[sm=punching.gif]
IL
RE: 3 blade prop HELP!!!!!!!
i think the rule of thumb is 1 inch less and 1 more prop degree... so 12X6 = 11X7? just an example.
anyone know where i can get some good 3 blade props and nose cones?
~Matt
~Matt
i was running a 2 blade 14x6 befor i change it to a3 blade
tru turn spinners are very good spinners,and 3blade prop's master airscrew.
My Feedback: (8)
You should check the thrust angle of the engine. The manual for the plane will tell you if the engine needs up,down,right,and left thrust. and maybe the incidence of your wing. If everyting is how it should be, I would not think that changing prop sizes should cause your plane to pitch up so much.
