servo chatter
servo chatter
I get some servo chatter when I turn the transmitter and reciever on-have not experienced this before-is this a low battery problem -any ideas.
servo chatter
Could be that, could be the Tx too close to the Rx and swamping it. It could be a few other things too but if it's just started in a plane which used not to do it and you haven't changed anything those are the most likely.
Steve
Steve
servo chatter
I changed the batteries in the tx to 700Mah aa size and am charging now-seems to work better all the time. I made sure non of the servos were binding on anything. Thanks for the info.
