OS Max .46 SF
Reply
Old 03-09-2005, 08:47 PM
LuckyArmpit
LuckyArmpit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS Max .46 SF
Isn't the OS Max .46 SF engine a ringed engine? And wasn't it the pre-cursor to the LA line? I know a guy who may be selling one
and if the price is good, may pick it up and run it on a Sig Kougar. How comparable is it to the AX line?
Dave...
LuckyArmpit is offline
Old 03-09-2005, 08:52 PM
Ed_Moorman
Ed_Moorman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS Max .46 SF
The OS .46SF was their top-of-the-line, ball bearing .46 and the forerunner of the FX series. It came in a ringed version and an ABN version. Most people opted for the ABN one, thinking it might have more power. What they got was one with a peeling liner and a ruined engine. If you find a ringed one, pick it up, it's an excellent one. Avoid the ABN one. I have one and, as I mentioned, it has a peeled liner.
Ed_Moorman is offline
Old 03-09-2005, 10:56 PM
ho2zoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with Ed. I had the ABN version. Ran great for about 2 years- then yuck! No power, bad idle, etc. Replaced the piston and cylinder liner and it ran good for another 2 years- then yuck again! Really put me off OS for several years.
But my OS .91 Surpass (ringed) has lasted for 10+ years!
ho2zoo is offline
Old 03-09-2005, 10:58 PM
Mighty Mouse-RCU
My Feedback: (145)
Mighty Mouse-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought it was the FX that had the peeling problem not the SF. Did they both have this problem?
Mighty Mouse-RCU is offline
Old 03-09-2005, 11:35 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All the OS engines with the ABN liners had this problem until late 2001.
The SF was not the fore runner of the LA series. The fore runner was the FP series of engines.
There was a guy on here the other night with a old peeled LA.
I've been around a lot of SF's and I thought they were pretty good.
Enjoy,
Jim
w8ye is offline
Old 03-09-2005, 11:45 PM
slapshot
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ed is right, the 46 SF ringed is a great engine. I have one in a Sandich Magnum, has to be at least 10 yrs old.
slapshot is offline
Old 03-10-2005, 08:44 AM
britbrat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a bunch of SF ABN engines & not a peeled liner to be found -- great engines. However, my first (& 2nd last) FX peeled it's liner.
britbrat is offline
Old 03-10-2005, 09:00 AM
LuckyArmpit
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanx! The engine is the ringed version. According to the guy who has it, has pretty good compression. Hope he don't change his mind though as he has acquired a 40 sized Cessna.
Dave...
Old 03-10-2005, 12:45 PM
tucker1865
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys...What causes the liner to peel...improper break-in, too much heat (a little added castrol) and would the magnum liner/piston fit. I have one, now I'm leary. Thanks Dave
tucker1865 is offline
Old 03-10-2005, 01:56 PM
britbrat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is nothing inherently wrong with having a nickel-plated brass cyl sleeve, as the nickel is very much harder than the high-silicon aluminum piston -- thus making the piston the critical wear component. I suspect that the problem with OS was inadequate thickness of the copper & nickel plated layers, plus problems in surface preparation prior to plating. It could also have been compounded by the brass sleeve being too thin &/or variations in the composition of the brass alloy that was used. These faults would make the engines susceptible to thermal damage. The failure rate was fairly low, and as it would be costly to re-engineer the piston & sleeve assembly, or the manufacturing process, OS probably avoided doing anything about it --- until their reputation started to suffer.
This is all conjecture on my part, but I think that it was the real-world situation.
ABN actually works pretty well -- Thunder Tiger has much thicker nickel layers on their ABN engines & has excellent reliability & service life.
britbrat is offline
Old 03-10-2005, 03:37 PM
Ed_Moorman
Ed_Moorman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It was my understanding that OS didn't copper plate prior to the ABL process. I could be wrong on this.
If you went back to the old RC Online, which imploded due to poor software, there were threads miles long on peeling OS .46 SFs & FXs. People were cussing OS left & right. They had to make a change.
As someone has mentioned, there were some fliers who never had a peeling problem. It seemed to me like these were in the minority, although the ones with the problem were naturally the most vocal.
The .91s, both 2 & 4-strokes were ringed engines so they wouldn't have this problem. The .91FX did have a leak, or somethng, with their remote needle valve. They have since replaced the needle with an assembly with one like that on the AX which works very well.
Old 09-11-2019, 06:49 AM
douglas racer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Interesting that people were having problems with the ABN version. I just changed the bearings in my 35 or so year old ringless .46 and the sleeve was fine. Did they make improvements? I'll report back in another 35 years.
douglas racer is offline
Old 09-11-2019, 10:17 AM
init4fun
init4fun's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where's Konrad when we need him ?
init4fun is offline
