Prop Choice
GA
Prop Choice
Hi, I have a Cub J3 with a saito 65. It lifts off and flies great but can't seem to get landing speed slow enough. The engine idles as low as I can get it and not die.I understand prop pitch has a lot to do with speed but do not have a clue as how to select the right prop. Saito recommends a 12-6 to 13-6,have tried both. What prop should I use for slow landings and good flight?
Dave
Dave
RE: Prop Choice
You didn't say which scale or who made it (Cub); not that it matters, except for wing loading and weight, which with the engine choice adds up to the power loading. I have a 1/5 scale Cub, 84-1/2 inch wing, weighed 9 pounds when first built, up to ten pounds now. I also have a Saito .65 in mine and have always used a 14-6 Master Airscrew K series prop. I haven't had any problems getting mine to land, as a matter of fact, I am usually carrying a couple of clicks of throttle all the way to touchdown. It may be due to the weight, which is a couple pounds more than the kit was "supposed" to weigh, according to the plans. I agree that a 14-4 may work, or a 14-5. 14 is scale diameter for a 1/5 scale, and the lower pitch will allow a higher throttle setting for flying. I like the higher pitch, I can tool around at 1/4-1/3 throttle. Play around with the lower pitch; I'd try the 14-5 and if you're still carrying too much speed and can't slow the engine any more, then try the 4 pitch, but I think it will be too low. What does your engine tach at its lowest reliable idle speed? I also have an on-board glow system, and it allows me to get down to about 2100 rpm. At that speed, you can almost see the blades turning.
If by chance you have a smaller, or substantially lighter, Cub, you might just be overpowered. You could downsize to a .56, still have that great 4-stroke sound.
RE: Prop Choice
I would also put something with a larger diameter and smaller pitch.
In case you didn't know, Pitch is how many inches the prop would move forward in one rotation.
