Aluminium Spinner Sizes
GA, UNITED KINGDOM
Hi all i am after an aluminium spinner to for my weston hype with west 50 engine but i am unsure what the sizes mean and refer to could anyone please advise which size spinner i need thanks Lee.
RE: Aluminium Spinner Sizes
Lee, what Minn said. Also look carefully through the instructions. It should say what size you need. Based on the size and pics of the plane, I'm betting a 2"-2 1/2". If you are going to use a wide bladed prop, check with Tru-Turn, they make what you need. You could also just Dremel a standard out. I have had to do this before, and it's not as bad a job as it sounds. Just go slow and check the fit often.
GA, UNITED KINGDOM
Cheers guys, so if i just measure the diameter of the flat circle at the front of the cowl that is what size i need? I will have to see if i can get hold of those tru-turn spinners over here as i dont fancy drilling one out.
Thanks again Lee.
Thanks again Lee.
INCASE ANYONE WANTS TO SEE THE PLANE:
http://www.flightmadness.com/hype.htm
I couldn't find any spinner info among the various links I found, it's an ARF.
VA
This may be obvious but what the heck....
The spinner size is determined by th eplane but the adapter is determined by the engine. If you go TruTurn they have a nifty little adapter finder on their website.
Mark
Mark
GA, UNITED KINGDOM
Not obvious to me thanks mark,
The thing is my engine isn't on the website although i think the engine is based on the Webra 50?
Then try one of these:
[email protected]
[email protected]
One of those should be able to help you.
Here are some more alum spinners to consider.
http://www2.towerhobbies.com/cgi-bin...er&FVPROFIL=++
BTW - This should be your engine: http://www.westonusa.com/engines.htm
the manuals don't list the crank thread sizes but there is an email address at the end of the manual where you might email and get the info.
www.westonuk.co.uk
[email protected]
[email protected]
www.westonuk.co.uk
GA, UNITED KINGDOM
Thanks bruce ive sent an e-mail to west to get the details for the engine and when i get them i'll send an e-mail to tru-turn to see what the score is.
Cheers Lee.
Cheers Lee.
Hi Lee,
I have ordered spinners and "custom" spinner nuts directly from Tru Turn in the past when I have been unable to find what I wanted here in Australia. They are great to deal with and the order has always arrived in the post within 10 days of placement. You will probably get even faster service to the UK.
Thoughts and prayers to all in the UK suffering the echoes of Bali and 9/11.
Cheers,
Colin
Cheers,
Colin
GA, UNITED KINGDOM
Yes thanks colin i will send tru-turn an e-mail and see what they have to say. I was down london at the weekend for the live8 concert so it really hits home just think of the carnage that could have been caused if it happened then with all those people in such a small area it dosen't bare tinking about.... I think that this may be just the start of things to come but that is the society we live in today, i am fortunate not to have known anyone involved but my thoughts are with those who do.
