Sig LT-40 Build (maiden a success!!)
#152
WA
RE: Sig LT-40 Build
Got to fly my plane again last night! Flew again with Nick on the buddy box. Made me grin ear to ear to see that thing go up in the air again. Practiced doing some circles and figure eights. Nick showed me how the rudder influences turns and also how to do a loop. That was pretty cool to do my first loop!. Next we practiced some ~30ft passes over the runway and learned about speed, turning and avoiding stalls. Practiced low speed downwind/base/final legs. Downwind leg was higher than normal and only had two clicks of throttle. Was sweet to start to develop a pattern for lining up a final approach and also learning to throttle up to gain altitude and speed before turning for another attempt.
One habit I have from console games is to tap the stick and let go of it to center vs keeping my thumbs on at all times... breaking that habit though.
Nick said I was about 1/2 way to my solo flight. Pretty amped! Next Tuesday is the last training night for the year but he said he'd work with me on a buddy box if we set up some time. Pretty generous of him and his time I thought. [sm=thumbup.gif]
I needed a box for my stuff so I had a tackle box that fit the bill just fine! Had an old Calvin & Hobbes sticker in my drawer that fit this pretty well. The Tx and starter fit perfect up top and the tackle trays are perfect for all the small parts, tools, etc.
Also picked up a smaller tool box for my power stuff.
I cut the alligator clips off the charger unit and added some plugs so if needed, I could use the alligator clips to hook up to my car battery in a pinch.
Added some banana jacks to the side so I can easily hook up the charger or starter. Gonna make up a cigarette lighter to banana plug adapter so I can charge this 7Ah 12V battery on the way to the strip. 25 minutes should top it off nicely.
somegeek
somegeek
#153
OR
RE: Sig LT-40 Build
somegeek,
Sounds like you are doing great. Nick always was pretty generous about making time to help out. The Calvin and Hobbes sticker is great. I built SIG's Mini Field Boss but I am quickly outgrowing it. I think I am going to end up building the Field Boss. It holds a gallon of fuel instead of a 1/2. Good idea keeping both thumbs on the sticks.
Gene
Gene
#154
RE: Sig LT-40 Build
Somegeek, First it's the just the plane. But then you have to have the field gear. Then it's "I just have to have that engine." But I need a plane for the engine too! And so it goes with no end in sight. Congrats on the finished plane, nice job[sm=lol.gif]
#157
Banned
RE: Sig LT-40 Build
Somegeek,
Glad to hear your training is going well. Have you thought about a second plane? Also do you have any pics of your plane in flight? Would love to see them if you do.
#158
WA
RE: Sig LT-40 Build
onlyb,
For my second plane... on my xmas wish list - a Sig Hog-Bipe w/ an O.S. engine(not sure yet what size) and an Rx w/ servos. The LT-40 was my first kit build, but I was very happy with the overall quality of the kit. The Sig Hog-bipe is a really cool lookin plane and a Sig kit to boot.
Will try to get a pic while it's in the air when I fly again on Tuesday. [8D]
somegeek
somegeek
#159
RE: Sig LT-40 Build
Somegeek
When you start building your second plane I be looking for you in the kit building forum considering your success on the LT-40 build.
Good luck on your upcoming solo flight.
#160
RCU Forum Manager/Admin
My Feedback: (9)
RE: Sig LT-40 Build
Somegeek,
The Hog Bipe is a great plane, I should know because I've had 3 of them. But not sure if it's going to be a good second plane for you. Maybe a third. But when you do build one, the perfect motor is the OS 91 Surpass 4-stroke. I think that this motor was made for the Hog Bipe. But the best thing about it is the sound!! A bipe just begs to have the sound of a 4-stroke on it!!!
Ken
Ken
#161
RE: Sig LT-40 Build
ORIGINAL: RCKen
Somegeek,
Ken
Somegeek,
Ken
#163
RE: Sig LT-40 Build
I agree with Ken, although you seem to be doing well, I wouldn't go with ANY bipe for your second plane. The Sig 4 Star series is a good second plane. The low wing with some dihedral flys almost like your trainer but is very aerobatic. Another choice is the Sig Something Extra. It is a mid wing design with a straight, symetrical airfoil which isn't as forgiving as the 4*, but still an easy flier. Both come as ARF's or kits, and the kits are very easy and straight forward builds.
#164
WA
RE: Sig LT-40 Build
Thanks for the advice guys. Guess I'll put the Hog-bipe on the back burner and maybe put an SSE on the wish list. Thinkin an OS .46 AX would pull this plane nicely?
somegeek
somegeek
#165
Banned
RE: Sig LT-40 Build
Somegeek,
I think you are right putting the bipe on the back burner. I built a Great Planes Cub as a second plane, An instructor at my club has flown it, and I have on a buddy box. My attempt at takeoff ended up crashing in the weeds (minor dammage). I'm building a 4* 60 now. Having a blast. What I can gather from just about everyone this is an excelent second plane. Have fun.
#166
My Feedback: (32)
AZ
RE: Sig LT-40 Build
somegeek,
I agree with the others... wait on (flying)the bipe - but nothing says you can't go ahead and get it....
The .46AX is a great engine, and would work nicely on a SSE I think. 4*'s are nice, along with the goldberg tiggers.
Going to be out of touch for a while.... found out that I get to go home a little earlier than expected.
I'll check back in about a week or so. Good luck, and keep up the good job with the LT! (pictures!)
#168
WA
RE: Sig LT-40 Build
I replaced the servo mounting screws with Dubro hex head servo mounting screws. Easier to work with than the stock futaba phillips screws.
After removing the servos, I used one of the hex head screws to tap each hole since the hex head screws are slightly larger than the stock servo screws. I then applied a drop of CA to each hole to strengthen them. Had to poke a few of them with a toothpick to break the CA in the middle of the hole so it was open. After they dried, I reinstalled the servos with the hex head screws. Sure like working with them vs the shallow headed phillips servo screws that came with the servos. No worries about stripping the hex heads.
Also read a tip a while back about putting a clip on the Rx switch to keep it from accidentally switching on while in transit and such. Mine is setup so out is off and in is on so this worked great - plastic clothes pin fit perfect...
somegeek
somegeek
#169
My Feedback: (9)
RE: Sig LT-40 Build
Somegeek,
I don't want to come off as being overcritical because you have done such a great job on this plane, but by looking at your pictures I can see that you may have overtightened the screws mounting the servos in. I can see the rubber grommets "puckered" in. You want to screw them in to just the top of the rubber, when you over tighten them the screw pushes down to the metal insert. When that happens it bypasses the rubber material and vibrations will pass directly to the servos which can destroy a servo. You want the rubber material to absorb vibrations. Take a look at the attached diagram.
Hope this helps
Ken
Hope this helps
Ken
#171
RE: Sig LT-40 Build
Those little hex screws are great. I buy them is bulk from Microfasteners. They have a great product line in stainless steel and some nice storage boxes/tools too.
#172
RE: Sig LT-40 Build
Somegeek
You should take a look at the great planes "easy sport" kit as your second plane.I just finished building it last winter and found it as a great plane to build and fly.I also built the sig 4* and personally like the easy sport.
#173
WA
RE: Sig LT-40 Build
Flew tonight for the third session of flights. It was pretty windy - about 10mph on the ground so who knows what 50ft - 100ft up.
Practiced again with Nick on the buddy box. Practiced some circles, figure eights, landing approaches, idle engine glide in approaches and fly/glide bys. I felt more comfortable with some of my idle speed glide bys than some of my 1/10th throttle fly bys over the strip. Since it was as windy as it was I didn't get to land or take off today but did get to learn how to do a barrel roll and some cuban loops/rolls for fun. Getting a little more comfortable flying and knowing how to react to normal/level my plane, but still shy with cutting the throttle back and such on approach. 2-3 clicks up works for landings but I forget to bring the stick all the way down and count up. Guess that will come with time. Enjoying doing approaches. To mix it up I tried a landing approach from the other end of the strip - did okay but talk about feeling odd.
8 flights and the plane is doin well! [8D]
Got some nice compliments on my kit build tonight. Made me feel good about the build.
somegeek
somegeek
#175
My Feedback: (9)
RE: Sig LT-40 Build
ORIGINAL: bruce88123
Sorry but 10 mph isn't all that windy. Yeah I know, you're just learning but it will get easier.
Ken
